ERF9530 MOSFET VERSUS IRF9530 MOSFET.
It's all about the speed. Since these parts are characterized to function as switches, the on/off delay times are your only guide to the max RF frequency it will amplify.
Here's the delay times for the IRF520.
And here's the FDA24N40F:
The FDA part is at least four times as slow as the IRF520. Looks like you won't get any real RF gain much above 7 or 8 MHz.
Then again, don't let me discourage you from trying. I'll predict that your power gain from input to output won't be much more than about twice the drive power.
Only one way to be sure.
Oh, and about that "gentleman's agreement" thing? Just remember the math. Two men can keep a secret if one of them is dead. My personal incentive is to spread knowledge, not conceal it.
Interesting note
The Rocket amps guy that uses Eric's 9530 devices stopped building for a while, rumors were that they ran out of mosfets.
Now they are going again and said that the new amps are 24 volt capable and more tolerant to higher SWR.
Yet still palamor says out of stock on erf's.
So I contacted them.
Here's the reply.
The ERF 9530 is no longer available.
Rocket is now building with this
The Rocket box RB 1942.
24 volt capable device.
Will update when I get more information.
The rebrand continues.....
Reactions: Eldorado828
Replied
The new device will replace the 9530 but it's not compatible so you will have to replace all the the ERFs with the new RB part to repair the amp.
Current cost $13.99 each from Rocket.View attachment 76129View attachment 76130
I suspect more snake oil. Did he get the recipe from E. Lewis and now rebranding them as his own? It's hard trying to unwind the whole scam these guys are doing with all the rebranding of parts. What happened to the days where the oe number was just on the devices and we could source the part ourselves! These guys not only want the customer base to buy their amps, now they want them running back to get the brand exclusive part from them too. It's all about the money and who cares about integrity i guess.
It's the same scam the auto industry uses to make us go back to the stealership.....
Reactions: Tim Chambers
Somebody did the research work I have studiously avoided. Arbitrage is a keystone of capitalism. Find something with a value that exceeds its price. Buy low, sell high, right? Yeah, the secrecy angle is annoying, but somebody figured it out. Feel free to do the same thing. The specs for the factory catalog-numbered part that was re-marked as an ERF or RB part is published, freely-available info. Nothing stopping you. It's the age of the internet. You don't even need a pile of thick data books to do the survey like in the dark ages. Semiconductor data is on the 'net now.
It's all in the numbers. The higher the voltage and current ratings, the slower a MOSFET will be. Bigger part means a gate structure with more area. Means more capacitance. Just scan all the data sheets for a rise and fall time under 25 nanoseconds, more or less. There's a disconnect between the switching on/off delay times and the 'rise time'. Haven't grasped the math there yet. Just the same, the faster the better. And the slower the spec, the lower your uppermost functional frequency will be. If you won't operate above 14 MHz, the list of prospects gets longer. And if 80 meters is all you care about, the list of possible candidates gets even longer.
The IXYS part looks promising:
The Fairchild part has been discontinued. The DigiKey listing is a drop ship from Rochester Electronics. Looks like they'll sell you all 150 in their stock or none. That company's claim to fame is buying up discontinued parts and getting a healthy markup after they spend years on the shelf.
The IXYS part is over 11 bucks until you buy 30. Then the price drops nearly in half.
Probably worth giving that one a tryout.
Reactions: NZ8N
The FDA24N40F looks to have way too much input capacitance to be good for 27mhz, even the irf520 has more than you would like.
