Galaxy DX2517 Troubleshooting Help
Q37 is the voltage regulator that provides a steady 9 Volts to the transmit/receive switching circuits. If it fluctuates like that, stuff gets twitchy.
I became impatient with fixing this regulator circuit. You pretty much have to take Q35, D72 and D73 each loose to test them. We adopted the policy of using a 7808T TO-220 3-terminal regulator to replace it. We add a 1N4001 diode between the chip's ground (center) pin and circuit-board ground.
The chip's center pin is in fact connected ONLY to the diode, not to the circuit board directly. The pic doesn't offer a clear perspective view of this.
The diode boosts the output of the 8-Volt chip close to 9 Volts. And if you can find a 7809T that's simpler. No diode required.
This radio probably won't behave itself until it has a steady source of regulated 9 Volts.
Reactions: Dr. Frankenstein
Okay i ordered the 7808’s from Amazon and will be here tomorrow. While I’m waiting today I might try that modification on the photo you provided with the stock regulator and diode to see if it works and get back with you later. Also, d72 and d59 have been replaced with 3 series 1n4148’s. Is that acceptable or could that cause a problem? And I have already replaced d73, and q35 with a 2sc1815 which according to the internet is a modern substitute for the original sc945.
It's always somethin, there was a solder trace that was loose from the board near q35 and decided to stop and repair it but when I turned it on I saw a little orange arc jump between two adjacent traces near the q30-q33 area I think from the voltage rail to ground and then lost power to the radio and the lights went out. I switched from crc to 91% alcohol and a tooth brush to clean where the arc was in case it was a carbon track or flux causing it. After cleaning that area I checked D110 and is good and d109 reads shorted but when I lift one end the diode tests good and there is still a short on the traces. is it possible that the t1 transformer could be shorted from the arc since it is also across the 2 traces that are reading shorted at d109? I appreciate the help and happy Easter!
Happy Easter!
A loose trace may been the cause of the fluctuation. T1 is a choke, not a transformer, and it is in parallel with D109 so the short you read when D109 is in circuit is normal. If we knew exactly where the arc happened, that would help.
We need to check voltages around Q37 again to see if that took the regulator out (after you repair any loose traces).
Happy Easter!
Between the end of jp81 and the end of the other short jumper next to it where the 2 red lines are drawn. With a pick it feels like it actually started to burn a small pinhole into the board between the traces but not all the way through. After it happened I noticed it was a little dirty around those traces from flux maybe so I cleaned it well with alcohol and a toothbrush and looks a lot cleaner. But now when I turn it on the power supply sees no current and the face of the radio went out.
So a short between the output of choke T1 and ground. The choke and the diode already checked out, so It probably blew the fuse or regulator on the power supply. Check the fuse first.
I have read most of what you posted. Replace D70 with the correct 5.1 volt zener diode, the finals and look very carefully around the ceramic disc capacitors between the finals and the antenna connection at the rear edge. You may find arcing from a possible lightning strike. I have fixed 4- EPT6900— radios that all were hit by lightning. The repairs have all been similar. Some had a bad Roger beep oscillator and some had a bad IC 1. Your keying problem is likely caused by D70 it will test good but can leaking current To ground and this will show up around Q33-34??? As lower than expected voltages! Hope this helps. The connection in this latest post is on off power distribution! Make certain you don’t have a shorted connection between those legs! Good luck!
@QuickdrawMcgraw He said the red (tx) light is coming on in receive. If the 5.1v zener were leaking current, that would be turning on the receive rail, not the transmit rail. And with R208 being 22k, there's no way that leaking current could draw down the op amp output voltage enough to turn on Q33. A leaky D71 wouldn't cause that either because Q33 is PNP and the voltage is too high.
Messing around with the switching circuits is pointless when the signal that controls them is fluctuating. The op-amp output only has to drop roughly 2.6v below the 9v regulator for the TX to come on, so that fluctuation is more than likely the sole culprit for the intermittent red light. And in my opinion, the fact the red light is turning on at all suggests the 9v rail is not fluctuating like the op-amp supply pin. Thats the only way Q33 and D71 can conduct.
A 7808? I don't think it was even established that the regulator was the problem. There's still the question of the loose trace, and whether that was the cause of the voltage drop at the op-amp supply pin or whether the op-amp itself was drawing excessive current. Maybe I missed something.
The short (arc) he reported was before the regulator. If you look at the spot he said it arced and compare that with the trace view on cbtricks, it is clear that the short was directly across the choke output and ground. With T1 showing continuity (he said the diode drop read zero when reinstalled in parallel with it), there are only three other things that could have been damaged from that short. The supply fuse, the supply regulator or the power switch. One of these three made the radio go dark ~ the 9v regulator was not involved in that event.
Proper troubleshooting takes patience. But, time is money, so carry on. Replacing random stuff until it works is a valid repair method, it's just not mine.
I’m sorry I got involved.
Loose wire, we talked before! I’m also in Florida, east central. I didn’t clearly understand all of the concerns with that discussion. If I were a little brighter I would have phrased it as something to be watchful for, not an absolute path of repair. I’m not in the habit of shotgun repair myself. Voltage charts are my friend, I use them often. You were absolutely correct in your statements on my comment! Thank you for caring!
Reactions: brandon7861
I was just going to post: Wanna buy a shotgun!
