Browning Mark: 4 old dog ponders new trick.
nomadradio
Analog Retentive
I Support WorldwideDX.com!
Apr 3, 2005
8,718
14,556
698
Louisville, KY
www.nomadradio.com
The Browning Mark 4A receiver has one crystal for each band it covers. The factory installed one at 22.82 MHz for channels 1-27 and 23.14 for channels 28-59. There was a crystal available to cover 32 channels below channel 1, 22.5 MHz.
They were available for years from Barkett Electronics, but I'm gonna try out a more high-tech alternative.
Stumbled across QRP Labs. https://qrp-labs.com/
In particular they sell a pc board with a SI5351 frequency synthesizer chip, the same "DDS" frequency source used in the Troy Radio gadgets. This one has no controls, other than three binary input pins. It's shrunk down to fit inside a HC6/U crystal can. My plan is to use three wires from the radio's front-panel band switch as inputs to this board.
They call it the ProgRock. https://qrp-labs.com/progrock2.html
I added the right-angle pins to make prototyping easier.
The mock-up here hasn't even been soldered together. The idea is to just replace the factory board and its crystals.
The ProgRock is eighteen bucks plus shipping. About what you'd pay for just one crystal.
Maybe.
My ultimate ambition is to make a pc board to use in either this receiver or the Mark 3. That will require a rectifier and filter to use the 6.3 Volt AC heater power to run it. The Mark 4A has a source of 11 Volts DC. A simpler place to start from.
Film at 11.
Maybe.
Film at 11.
I will be following this, I have a few friends who run old radios on the weekly Old Tube Radio Network that try to keep them alive, this may keep a few more on the air.
Thank you Chris.
This project hasn't quite made it to the breadboard and jumper-wire stage. Seems like starting with a schematic would be wise. I hear echoes of my dad who wouldn't let me touch his pile of wood "scraps" before showing him a drawing of what I was making. And how much of his wood supply I would ruin.
Here's the pinout of the Prog Rock synthesizer module. It has twelve foil pads on the top side of the pcb. And another twelve on the bottom side. For simplicity I'm using only the top-side pads Makes it more convenient connecting to the right-angle "spider leg" pins alone. The bottom side pads will be clumsy to reach and connect to this way. The input voltage on our two band-select inputs should not exceed 3.3 Volts DC. I puzzled over the board's 3.3 Volt regulator output appearing on the lower side only. I considered some clumsy ways to borrow power from that pad, and use it to feed a 3-Volt logic high signal through the band selector switch. Seemed the logical way.
And then my idiot light came on. The band selector feeds 11 Volts down one at a time of two wires already. I'll use a series string of four 1N4148 diodes in series as a clamp across each of the controller's two input pins. The 10k Resistor on each input limits the diode current. The controller's input pins will see just under 3 Volts. Should conrol it as a proper logic high input.
I only need two wires to select three bands because the controller's input to select eight frequencies is a 3-bit binary number. The three binary input bits are labeled "Bank 0, Bank 1 and Bank 2". With no input voltage to all three pins, this is frequency zero. When the "bank zero" pin goes high, frequency number 1 comes out. And frequency number two is selected when "bank 1" --only-- goes high. And Bank zero goes back low. The radio already provides two wires to select bands, and that's all we need to select one band out of three. Too easy.
Yeah, the ProgRock stores five more frequencies but we only need three. Besides, the Browning receiver design is being stretched to cover three bands. The radio's design is just too narrow-banded to stretch its coverage any wider. Feel free to try it with four bands. You'll find it's a bit weak on one of those four bands. Which one it will be is determined by how the radio is aligned.
In the interest of open source, here's the schemo.
With any luck I'll get some slack time this weekend to pick up where I left off and actually try this trick in a radio.
Maybe.
Got a suggestion to just use a zener diode to hold the module's select-input voltages below 3 Volts. Duh! Sometimes you just gotta acknowledge advice from Captain Obvious. Credit where credit's due. Thanks.
Had some issues years back with 1-Watt zener diodes below 5 Volts. Had to push a minimum current into them before they would behave. But it turns out I had some 400 mW zeners in the inventory. They behave just fine with a 10k resistor gator-clipped to 11 Volts. The ones rated at 2.4 Volts seemed a safe place to start. Sure serves to simplify the layout. Eight 1N4148 diodes would have been crowded.
Gonna try perfboard first.
The long bare wires will solder to a ground lug under the mount screw. Forgot to bring some of them home.
If it works well enough to graduate to a printed-circuit board, the layout won't look so tortured.
One look at this and Davey Jones would pipe up with "That's pretty how-ya-doin".
Now to take it back to work and see what it does inside a Mark 4A receiver. Almost 20 years ago Epson sold a programmable clock generator. Was in the same metal can as the fixed-frequency versions, but programming it required an expensive gadget. Digi-Key would program them to order. Tried them in a Mark 4A receiver and it was just too noisy. A look at the waveform revealed a pretty tortured funky square wave with odd spikes on it. It was meant as a time base for digital circuits after all. Was just too noisy to use as the local oscillator in an analog receiver. The Si5351 is an evolved design that should behave a lot better.
Fingers crossed.
Film at 11.
The weekend is when design projects get tried out. And:
EET VERKS!
Mounts where the original board with two crystals went.
Only connection to V3 is pin 2, where the hot side of the original crystals went. The tiny orange ceramic blocking cap has unnaturally long lead wires. Not totally sold on the injection level to V3, but it hears just fine, and no random 'birdie' noises I can find.
Wanted to select three bands using just the original two wires yellow and blue.
The blue wire is active on the "XTL" position of the band selector. This is the binary "one" input to the ProgRock. Selects channels below 1. The yellow wire is the binary "two" input, selects the "HF" band. The two diodes are fed 12 Volts from the "CB" position. This drives both the one and two inputs to the ProgRock for the binary "three" input. Two diodes seemed easier to install than a third wire.
There is originally a bare jumper wire that connects this lug (with the two diodes) to the one with the blue wire. It was needed for the factory-original fixed-crystal feature. It has to be clipped. One cut-off end of it is visible here.
Next steps are to try it in a Mark 3, and produce a printed-circuit board to make it saleable. Not gonna try to sell perfboard kluges.
But IT VERKS!
Big sigh of relief.
RTFM they say. In this case I really should have. Turns out the three binary inputs that select one of eight frequencies stored in this gadget are internall pulled *UP*! NOT down.
Whups! If that's the case, this hookup should not have worked. But more to the point, I don't need to feed a logic-high into the three select pins. With nothing connected to the three inputs, you should get frequency number eight. But only if you set it up with a frequency stored in slot eight.
To get "bank" zero, all three binary inputs should be grounded, right? I haven't rewired it for this yet, but here is schematic version one point one.
With any luck I'll get it rewired to try and see if I'm right. Since I can't explain why it worked violating the instructions, I can't very well copy that setup and call it a product design. With any luck, this version will work as predicted.
Film at 11. Or maybe after the weekend.
Reactions: AudioShockwav
If floating inputs are valid high, could you move SW1-C's common from hot to ground?
That's the plan. Removing the pink wire feeding 11 Volts DC from the common lug on that section of the band switch will allow splicing it to the power wire for the module. A ground wire will go to the switch lug. The idea is to minimize how much stuff gets altered in the receiver. The fewer steps to install it, the fewer possible errors to worry about.
RTFM part two: The three binary inputs that select one of eight stored frequencies are indeed inverted logic.
That means a "zero" is a logic high, or 3.3 Volts. And a binary one is logic low, or ground. The manual doesn't say so explicitly, but it does say that if you don't connect anything to those three inputs, you'll get "bank" (frequency) zero. Makes sense, that you'll get that frequency if you simply stuff it into the metal can of a HC6 crystal. No room for select wires in that application. I didn't put one and zero together at first from that hint. The simplified setup works as intended. The band switch selects a ground connection to two inputs only. The default frequency is the "CB1" position, with no input to the ProgRock.
No zeners, no diodes, no series resistors.
The band selector had a pink wire feeding 11 Volts DC into either the blue or the yellow wire. A bare jumper wire joined the "CB" and "Xtl" positions. The cut end of the bare wire is barely visible. The pink wire was removed and a bare wire to a ground foil is on the common lug of this switch section now. The Yellow wire gets grounded for the CB2 band, and the blue wire for the "Xtl" position, where the lower-channel tuneable band is now.
The pink wire gets lap-spliced to the red power lead for the ProgRock.
Might look a little neater if I had gotten it right the first time around.
I'm not completely satisfied with how much drive the grid of V103A is getting. I did ground the cathode at pin 3. Helped a little. Gonna try a two-to one toroid transformer to step it up between the ProgRock and the tube grid. If I can find the bag of tiny toroids.
And if it doesn't help, that's how I'll find out.
Ordered the prototype batch of pc boards from ExpressPCB today. Gonna try it in a Mark 3 once they arrive in about a week. The tiny TO-92 voltage regulator got upgraded to a TO-220 type. Yes, it's overkill, but the to-92 part was warm on the verge of hot. Figured that inside a tube-type radio with the clothes on it it could trigger the built-in protection and shut itself down. If it's warm out in the open, it will be hot cooped up inside a box with hot tubes. Sure wish I knew where I put a bag of tiny toroid 2-to-1 transformers. They were a "can't resist" flea market item. Now that I have a use for them they're hiding. I suspect the Mark 3 will need the extra drive.
Maybe.
What if, instead of using a broadband transformer, you used a resonant tank to boost the voltage? Maybe one of those propane-salvaged cans with the internal cap lead cut and externally resonated.
