Big switching power supplies - what's the forum favorite?
I've an Astron RM-50M under my desk. It does the job year after year. No RF hash and no fan noise. I detest fan noise, especially if it is continuous. Some switchers are temperature activated while others run the fans continuously. Those that have a tiny fan may sound like they're ready for takeoff!
I've a Samlex installed in a TKR-750 repeater that I'm testing here. Its fan is temperature controlled and the power supply appears to generate very low RF noise, at least I don't notice it. This is another important consideration, especially on the lower HF and MF bands.
You might see if you can get a 100% refund guarantee if you're not completely satisfied with whatever you choose.
12V, 76A Delta surplus server supply I modded to 13V and slapped some binding posts on. Tiny little thing for the wattage, but sounds like a vacuum cleaner running under the bench o_O
A lot of folks here love their switchers but I invested in an Astron RS-35. Runs everything except amp with zero RFI and it's completely silent. Steady 14vdc and 15-20 amp peaks that never waver. I power it up and forget it's there.
My pyramid 52kx took a dump on me so I got a hold of 2 HP server supplies and put them in it's case. Now I have a rock solid 200 amp supply that will handle just about anything that I would throw at it.
Pyramids are CRAP. I have worn out enough of them to fill up a dumpster. I use Only ASTRON Power Supplies since 2002 & they have never let me down.
They're good re-engineering projects ;)
My friends & I found that those & the Tripp Lite power supplies made great dumpster materials. Tripp Lite could not even provide a schematic that included the parts because they told me they were built in Mexico & they were not sure what parts they had in them.
70 amp Astron. Its probably overkill but it's never been stressed with the amps in the shack. I actually dont know if I've ever pushed it to the point the fan kicked on..
If the fan comes on you will for it. I was running a 350 watt TE Systems amplifier with mine & working a pileup. It came on & it Scared me because I had never heard the fan. It has a very noticeable sound. I have (2) of the RS-50 amp Astron supplies & I find it strange that they don't have a fan at all?
I've a PYLE 60/65 psl642x and I've never had an issue. I also have some Astrons RS-60 and Tripp-lite pr-60. Never had an issue with any of them, and I have some smaller version of both brands...big, heavy, and reliable.
I use a megawatt but the fan was too loud. Added 2 24v fans from the junk pile and it is silent and never given any trouble. It is kinda ugly though.
I built two of these HP150/200A server supplies about a year ago.
No issues whatsoever.
Load tested with a carbon pile tester. 14.5 VDC 150A @ 120V 200A @ 240V.
Fans are whisper quiet unless you put a heavy load on them...then they spin up a bit and sound like a jet...lol
Reactions: VMC
Tripp Lite. Ooof. What a pile of manure those things are. I stick with APC gear for my UPS's......never let me down yet.
And my Megawatt 36 amp power supply has been running for several years now 24/7 powering my radios and amps. Zero complaints; like the energizer bunny it just keeps going and going and going and going. And it makes no RF noise whatsoever!
Reactions: W4KVW
Thanks for the comments so far. I'm either going with a pair of RS-70s or Megawatt units of similar current rating.
As far as fan noise: I have a 2U Dell Poweredge server in the shack for running lots of VMs, and am going to add a couple more later-model units to that layout. At full load those things sound like a jet spooling up. The PSUs will be located behind a set of acoustic baffles but near enough to feed the gear without voltage drops. It's good that someone posted their experiences with a 300w class amp as that's what I'm planning on using on 6 and 2. Possibly 222 and 432 if they can be located.
