That is very kind of you, thank you. However, this radio must remain stock (or as close as possible).If you need I can send you a 40+ and 40- crystal no charge if you want to add extra channels
Ok ya those are nice radios and kinda rare dont see many of them aroundThat is very kind of you, thank you. However, this radio must remain stock (or as close as possible).
Thank you. I'm interested in what they say. Brandon is working on a synthesizer to replace hard-to-find xtals, I'm patiently waiting for a prototype to play with as I have a few rigs to try them on.Well good luck and will let you know what Bomar replies back with
I did see that and there is a guy over seas doing that programing crystal oscillators.Thank you. I'm interested in what they say. Brandon is working on a synthesizer to replace hard-to-find xtals, I'm patiently waiting for a prototype to play with as I have a few rigs to try them on.
It will need an analog input for the clarifier, but as I understand it, he's tackling that feature.Brandon is working on a synthesizer to replace hard-to-find xtals,
Minimum to order was 600 xtals so 1200 xtals for the 2 frequencies at 1 time about 5 years ago I had ordered 12,000 crystals.Hey Techno1:
Following this with interest. Can you share the information you provided the Xtal provider in PRC that got you in spec crystals please. As some have said, sending a working one to a Xtal manufacturer has advantages however not always possible, so keen to know what specs were provided to them that gave you your excellent resulting Xtals.
Do the Xtal manufacturer have a website? did you have a minimum order. Keen to know if its a route to keeping this as original as possible.
Thanks in advance.
Many Thanks Techno1 and apologies for making you repeat yourself, I hadn't noticed the thread had moved on since I last refreshed. You already posted the info. That's why I deleted my post but you must have got it before it went. Apologies again.Minimum to order was 600 xtals so 1200 xtals for the 2 frequencies at 1 time about 5 years ago I had ordered 12,000 crystals.
Here are the specs for the pll02a crystals, Other radios might be a bit different.....View attachment 77695
So here is a reply from Bomar xtal Price the same but minimum is 2 xtals @ $60 each so minimum order is $120.00Its Bomar crystal in Middlesex N.J
What happened to the crystal????
12kHz is a stretch. It may work, but the capacitance required will be very small. You will probably need a 1-10pF trimmer and it may become a theramin if the capacitance required is in the lower half of that.I saw that, but I'm not sure if they can pull 12+Khz. If you think so, I will try.
I have soldered the leg back on without opening the can, it will have to do for now.12kHz is a stretch. It may work, but the capacitance required will be very small. You will probably need a 1-10pF trimmer and it may become a theramin if the capacitance required is in the lower half of that.
What about opening the can and replacing the bad leg?
