Can we talk about the Cherokee cbs500 and 1k swing mod?
Harley3315
Well-Known Member
Oct 22, 2015
248
32
58
45
Anyone got a better plan here? swing mod like j36 mod and a better way to bring up modulation cause the way that's listed now sucks with
aany power mic at all! or maybe some hifi?
Had a paper copy back in the day. Haven't seen that model in decades. Was popular when Copper was selling it in the 90s. I'll see if I can turn it up. Our paper library has suffered severe neglect since putting day-to-day schematics on computers. I have no recollection of how "J36" applies to it.
Reactions: Harley3315
I just think we could make this a performer with a bit of work hope to see what we can come up with soon!
I worked on a Radio Shack TRC-495 a few months ago,
in another internet personality of mine. Same radio
as that Cherokee CBS500. I could not find a schematic,
So just did my own thing. Made a new power supply
regulator circuit. I was able to overmodulate it with
the stock microphone. make it sound "nasty" CBer style!
(click on this link) - Radio Shack TRS-495 repair -
So make sure the power supply is adjusted to around 13 volts.
I bet the CBer "golden screwdriver tech" will turn the voltage up
to 18 volts or so, and have that grin on his face that he is
getting something he is not supposed to get, like "doing" the
Hooters waitress and his wife does not know. :) :)
Maybe getting an extra watt of RF output.
The variable resistor for this power supply repair job
was turned up all the way. Not sure what the output
voltage would be, since it was blown up. But turning this
voltage to high will really affect the bias voltages
through-out the radio.
At some point, things will get worse.
I have a Cobra 142 here, and it has an adjustment
for the 12 volt power supply also. I bet back in the
day, "they" were turning it up to 16 volts or more.
I thought i recognized that model of realistic.
Here's a thread i made a long long time ago when i was working on one of these for someone.
Its about all the info you're going to find on it.
the thread doesn't really address increasing the modulation aside from mentioning which pot is the AMC.
to "swing mod" a radio like this, your best bet is to add more anti-spiking diodes in series with the existing one.
if the radio uses a modulation transformer, you'll find it in the rear right corner on most radios. looking at the output lead of the transformer, you'll find a large black diode connected there.
remove this diode and add as many 1N4003 diodes in series with it (all banded ends facing the same way) as you need in order to lower the deadkey to where you want it.
each diode will lower the voltage to the collectors of the driver and final by .7 volts.
however, your modulation level will remain at max because when you key up you forward bias the diodes, which allows the modulation to be coupled through 1:1.
LC
