I recentlly aquired a 100 mhz scope comes with probes, what else is need it to test my cb radios modulation?
Here is a great suggestion to people who know what they are doing.
I would LOVE to see someone do a great YouTube video on hooking a cb up to a scope, and explaining what to look for, at, and so on.
There are a lot of YouTube videos on scopes, but if you search for something that deal in radio cb modulation and adjustments and how to read it on a scope etc it becomes thin pickings and hard to understand.
Kind regards, on behalf of the noobs. lol
I did the same, but inside my watt meter. I only ran a grounded U fairly close to the antenna wire. It picks up milliwatts to well over a KWIf all you want to do is look at modulation it doesn't have to be complicated. The blue wire wrapped around the output of my amplifier is connected to a bnc connector on the back of the amp. That connects straight to the scope. Works from less than 1 watt to kilowatts. Also a good way to mount a bird line section to your amp and save a jumper.
