102" FIBERGLASS ANTENNA
I have the skipshooter and the firestik 7 foot antennas that i had experimented with out here on my apartment balcony stationary rail mount.
My dumbass forgot that i was useing 75 ohm coax for cb radio and ended up cutting the entire top load off both antennas to get a 1.1 swr and they both reallly get out there and still perform significantly better than the previous wilson 2000 trucker i was useing before.
The top loads on both antennas was about 10 inches that i cut off and even tho theyre both ruined im still useing one with the 75 ohm coax with an swr of 1.1.
Hi. If you use 75 ohm coax, antenna length is shorter ?
