102 inch antenna
Early this morning, I went into a Bosselmans truck stop, in Nebraska, and found some 102" steel whips. I bought two of them.
Oddly, they had no 6" springs to go with them. Nor did they have anything else with which to add six inches. That's ok, though. I'll find it, elsewhere.
SS.
I used a short chunk of SS rod 3/8 and thread both ends, then a nut on the top end for the XYL's truck. (she runs a DX 979 with 102 whip)
Just wondering, do many ops use the 102 inch mobile antenna in the usa?, what is the most popular mobile antenna do you think?
I don't see them as much these days. A lot of trucks in the oil fields used them for radio and with flags on the tip made them visible for on coming traffic especially on hills.
I always thought they looked cool mounted on the back of the old Willy's jeep.
1 quarter of 11 meters is 2.75 meters, which equals 108.2677 inches.
So, the extra 6 inches is to stretch that 102" antenna out to 108", which makes it closer to an actual 1/4 wave.
What formula are you using to come up with 108.2677" ? I use the standard 234/freq to calculate 1/4 wave verticals. That's gives 103.3" for 27.185 MHz.
The last two stainless whips I found at a ham fest were not quite 98" tall and worked perfectly on 10 meters with no trimming required.
I seem to recall reading that the MFJ 108" whip actually measures out at 102" which is close to 103.3". Maybe someone can verify.
Reactions: 222DBFL
A quarter wave in free space in feet is 246/f. 246/27.185 is 108.589 inches.
Since nothing is free, they stole some when they made the formula for a dipole :)
I'll measure my MFJ whip from HRO when I get home later today.
I bought 2 108's from MFJ 2 years ago and they were 9 ft, not 108… :D
I divided 11 meters by 4, which gave me 2.75 meters. I then went to Google, and had Google convert 2.75 meters into a measurement in inches. The result was 108.2677 inches.
I suppose that, since I am most frequently on Channel 19, I could tailor the antenna to that specific frequency, but would the effort be worth the reward? (<~~ Actual question, by the way; not being sarcastic )
  • @ heartbreaker3473:
