142 GTL Frequency Synth Error
LeapFrog
Wielding Hanlon's Razor
Feb 15, 2016
1,712
921
123
Tampa, Florida
Cobra 142 GTL failure to TX / RX
Loop Osc counter @ TP1
USB reads 34.75726
LSB reads 34.75724
AM. reads 34.75725
Counter @ TP3:
USB reads 7.80248 MHz
LSB reads null
AM reads null
VCO voltage measured @ TP9
1.7 VDC, adjustment of L13 changes nothing.
Any insight is greatly appreciated
Update/Correction
TP1 Tripler
USB: 32.61215
AM: 32.61235
LSB: 32.61225
TP9 VCO Voltage
1.7 Volts (doesn't change w/channel)
TP3
USB: 7.80250
AM: 0
LSB: 0
Clarifier Pot:
1 leg 8.3 Volts constant
Wiper to VCO
Last leg directly to GND!!
(Here I placed 8K Ohm)
@ TP1 max rf with L14 slug almost all the way flush with the top of the can.
Time for me to look at the schematic, critical thinking, perhaps a little simple math!
On top of that, you have several other issues with Age I think you'll need to be addressing...
The UHIC chip - note the discoloration at the base leads going into the board - looks like something is going on reactively to the leads. See Pink Arrow.
You're getting lower MHz readings - you supposed to get a free running 35MHz + so you 3MHz low usually this means other problems too...
Note the Orange arrow pointing the your L19 - may mean an internal cap failed - so you know. Nothing serious but for best "Hints from HELLEN" - turn the slug in two turns and try a retune around it. IF the Frequency won't raise up or even get close to 35MHz free running (you may or may not get lock on this) - if you don't get anywhere - remove the coil and check the slug problem - you may have one in that one too.
Yellow Circle and Arrow, you have the "glue" that others have discussed as possibly reactive - which if you try to unsolder this - be gentle - it's not welded on there - those components are soldered to a simple board internally.
1977 date code on the MB8719 PLL chip.
Might be more than just one issue in a 1978 or 1979 radio.
Never learned to troubleshoot a PLL without a 'scope.
Seeing 10.24 MHz on pins 7 and 8 is where I would start, followed by pin 17.
Those are the two input signals the chip depends upon.
Reactions: Handy Andy
    Scheduled for Jul 4, 2026 Saturday Live Streams:
    To celebrate the 250th birthday of our great nation. We are giving away not just one, but multiple antennas! The Grand prize is the CaHR-Tenna Hydra Antenna, along with several other antenna prizes that will be announced throughout the giveaway. Whether you're a new ham, portable operator, POTA activator, or an experienced HF operator, this is your chance to upgrade your station. Prizes Include: HRA Hydra Antenna (Grand Prize) Additional antennas from HRA More prizes may be added during the giveaway!
    CQ Worldwide VHF SSB/CW Contest: 1400Z, Jul 4 to 1400Z, Jul 5
