142gtl mystery vr pot
jimmy360
Oct 29, 2021
38
4
18
50
I have a 142gtl board pc-385AG .what does this vr does it’s not listed in sams photofact .thanks
there are quite a few variations of this board as it was used in a few different radios and was produced for over a decade.
for example, the Teaberry Stalker XV is basically the same radio you have there, but would be 385AD and would not have that pot, nor the holes for it.
you have a later version.
I'd be willing to bet that if you followed that white wire that is right near the top of that pot, you'd find that it went to the dynamike control, which would mean that it's for modulation.
earlier versions of this chassis did not have an internal AMC adjustment and you had to add/modify if you wanted one.
I do have a book at home that i know talks about this VR.
I'll try to remember to take a look at it later tonight.
LC
LC
Thank you buddy
LC
thank you
LC
White wire goes to front of the radio next to d70
yep that's the AMC pot.
There are washingtons out there with that board version as well.
before you go messing with it, you should make sure that TR32 and R105 are intact and not cut/removed.
LC
Reactions: NZ8N
