Have a local buddy who has a Palomar Elite 300. (2) 1446's. He says you have to run minimum 3.75 - 4 watts from radio and all is okay. If you run a lower dead key like 2 watts, then the amp hangs up while transmitting. That is, you unkey the radio but the amp keeps on tx'ing. Have to turn amp off to kill the TX.
This sounds normal to anyone? I think the key up relay in the amp is going bad or something?
What do you guys think?
