216MHz receiver?
brandon7861
Loose Wire
I Support WorldwideDX.com!
Nov 28, 2018
2,649
2,947
293
I am looking for a HT that has the best sensitivity that I can get between 216-220MHz, any suggestions? I know most radios have wide RX coverage and that any triband radio would probably suffice, but for my task, I want the RX tune to be the best it can be at 216-220. Edit: Another issue is that it cannot be FM only, it needs to have SSB or CW reception as the signal I am receiving is very low duty cycle OOK.
I currently use a Field Marshall FM4000 receiver for tracking down my cat, but I would like a backup receiver of comparable quality that doesn't cost so much. If he would stay within a half mile or so, a junk radio would work fine, but he likes to wander so I need a receiver that will work well without needing a 10 element beam attached.
AOR, Icom IC-Rx, some scanners work at that range that are pretty good.
I use a Kenwood TH-F6A for an application like that, which requires SSB demod at 220 MHz.
Reactions: brandon7861
I have never heard of those, but I will check them out. The AOR looks very interesting as I have never owned a good quality receiver, but wow they sure are spendy. I will look into those as well, thank you!
