4cx5000 help
I got to where I can't operate an amplifier without a 'scope on the output.
Let alone troubleshoot it.
Just seeing if the modulation peaks are reaching double the amplitude of the carrier would reveal a lot.
When your AM PEP is four times the carrier power, a Bird should hold steady with modulation, or kick up just a little.
I'd be happy with 12kW peaks on that tube.
Eimac's advice for the filament on that tube is pretty clear. 5 percent regulation. The procedure for a broadcast transmitter was to reduce filament voltage until RF-output power just begins to fall. Bring it back up just above that point for longest operating life. This is not so clear-cut for the transmitter in a 2-way system.
While I'd be happy running that tube at a 3kw carrier and 12 kw PEP, I wouldn't be so happy knowing that this was all it could produce because it lacks headroom where there should be plenty. The 4CX5000A should have enough peak emissions to produce double that in ICS. Even a 3CX3000A7 can hold about 6kw on the Bird with a strong tube and power supply. The 4CX5000A has a third more filament current to support more emissions but this amp is not showing that capability yet. This tubes internal structure is identical to the 4CX10,000D but just has a smaller cooler. Something is holding it back.
I've got a 4cx5000a setup for mobile use in my truck with grounded screen and grid and can't get more than 3kw rms at 7500v with plenty of current to spare is there a different way I should go about this maybe?
Feed input into the grid with approx -300 volts ( adjust for .5 amp plate current no signal) and 1200 volts on the screen and you will get more power
