8-Tube GTO
Hawkeye351
Jun 27, 2021
871
786
103
58
Ok, got the 8 tube GTO today. Everything looks great other than the center holes of both SO239's are wallered out big time.
User got rid of due to not keying up anymore. He said he was talking on it and heard an arc around the rear corner and it smelt like electrical arc, then it wouldn't key any longer. All wiring looks great and firm, no visible heated parts or cooked/blown parts, lights still come on, tubes still light up as usual.
I think the arc came from the center of the jumpers pl259 tip not making contact with the center hole of the SO239. Seriously, I have never seen so239's wallered out this bad. I honestly don't see how it was even working for him.
Reactions: VMC
Had a customer years ago who made his own coax jumpers. His claim to fame was a carefully-crafted ball of solder on the tip of the center pin, a bit bigger around than the pin diameter. Thought it would improve the connection.
What it did was to waller out the SO-239s in everything he brought me to repair. Had to bend them back inwards before my stock center pins would even make contact at all.
Pretty sure I hadn't heard of Dunning-Kruger back in those days.
https://en.wikipedia.org/wiki/Dunning–Kruger_effect
  • Wow
Reactions: Hawkeye351 and VMC
Ahhhh yes, Dunning-Kruger. I deal daily with self-annointed audiophiles (audiophools) that do the same to otherwise nice (and expensive) rhodium connectors. RF ain't the only place full of "Ah kin make it werk bettah by...." :rolleyes::ROFLMAO:
Checked all the tubes in it today. It has 17JF6 tubes.
5 tested great at 75%, with no leakage seen while holding test button down.
3 tested at 25%, 2 of which held at 25% while holding down test button but the other one would start falling lower than 25% the longer I held the test button down.
I'm thinking either the keying transistor (C945) or the coil in the relay is shot.
I did notice the load control (air variable capacitor) looks like it had welded together at some point in time and someone freed it up, but it won't go all the way around, it stops at the bad spot.
Probably can't just pull out melted plates until it frees up. Is there a safety choke in parallel with the Load control? Leaving it off can cause arcs on the Load control's plates. Depends on the antenna you use. A series-fed antenna that tests open-circuit allows DC voltage to build up on the Load control's plates piggyback onto the RF voltage. The two voltages added together are more likely to arc than the RF voltage alone. A safety choke places a DC short across the Load control's plates. Only needs enough inductance for your RF output to ignore it. And a shunt-fed antenna like a 5/8-wave vertical tests like a DC short circuit. That tends to take the place of a missing safety choke.
They call it a "safety" choke because it's there in case the final's blocking capacitor were to short. That would put the full plate-circuit DC voltage onto the antenna. The safety choke is there to overload the power supply and shut it down before a thousand Volts DC or more can go up your coax to the antenna.
This is the Load control used in the Pride DX300:
https://www.rfparts.com/capacitors/capacitors-antennaload/x764.html
If it fits, it should work.
