800 watt amp transister or tube?
dejaskysdad
May 21, 2013
16
39
whats are the pros and cons of transistor and tube gonna be pickin up a tube amp shortly but not sure whats gonna be the best guy says when the tubes are hot he get about 800 watts but I get that out of my transistor amp whats gonn be the better choice? my radio is superstar 4900b and antennas are antron99 and syrio 4 element beam.......thanks for any input..73's
That would depend on what the amps had in it for tubes or transistors. People tend to overstate the real output. IMHO a solidstate amp is for mobile operation while a tube amp is for operation at home where AC power is available unless you want to have a HUGE beast of a power supply to run a high power transistor amp. Of course there is always the option of using a MOSFET amp on the base which requires a 50 volt power supply and then you could use a computer server power supply to power it. That's my plan for 1200 watts on 6m. :D
Dirty radio,very dirty signal.Plain and simple.Get a radio that has filtering,and the limiters not cut,and you will have a clean and good signal.
    boog351 has left the room.
