Okay so I put up my new antenna it is a sirio vector 4000, and I am getting during the day a solid 9lbs of noise than at night it will go down to 1 to 3lbs, I have the antenna on a push up pole, I think it is a ground issue because I have another radio hooked up to the same antenna and it is getting the same noise
what is the best way to ground the antenna? also what type of grounding equipment should I use?
all I have in town is a radioshack, lowes and a home depot and a ace hardware.
any help would be greatly appreciated
