Alpha Antennas
binrat
WDX Club Coordinator
Staff member
I Support WorldwideDX.com!
Nov 5, 2008
2,633
1,566
173
The Great White north
Has anybody got feedback on these antennas? I'm thinking of the ProMaster Sr Base for home and camping or possibly the 6-80 Meter Vertical.
Not much room in the yard for an antenna, no restrictions except the neighbour who have too much time on his hands.
I have the Alpha Promaster Jr. antenna. I've had it up 6 months.Worked 64 countries on various HF bands and 3 states on 6 meters.It took about 45 minutes to install...a real "plug and play" antenna. Extremely pleased with antenna. I'm not affiliated with Alpha antenna in any way. 73 and good luck....K4BAD
Well, I have ordered the ProMaster Sr Base. Hopefully it will be here when I start holidays in just over 3 weeks. if it is then lots of use while camping throughout Alberta and BC.
I'll post up some pictures when I get it.
Binrat,
How did this work out for you? Can you post a review?
Thanks!
Jim
Hi Jim,
I used it for semi-portable (car camping) for 2 years. Set up was a used tripod like what they use for TV dishes on roofs, 7' of 1" conduit and I added 6' of para to each radial. Numerous contacts but I sold it last year. When camping now, I'm hiking uphill to activate a SOTA summit.
Short answer, it might be what you are looking for, for your QTH.
Hi Jim,
Thanks, binrat.
I have one of those tripods.
Is the system weatherproof enough for permanent use?
And does the vertical handle wind well?
