ameritron 811-hd
I’ve bought/sold on QTH for years without an isssue. When you respond to an ad using the email link the listing persons phone number is there so you can call them.
The CAPTAIN is right “one of the better places to deal on!”
ok check them out again..what type of plug do I need on the end of the foot pedal???rca or a quarter inch phono plug??
Whatever fits the amp you are going to get. I have seen some amps (Juma from Finland) that take a 1/8 plug. The AL-811H takes an RCA connector.
same plug for the ameritron right?so would it be feasible to spend $1000 on a heathkit sb220 that's somewhere around 25 years old or spend $950 on a new ameritron al-811h with less watts with a warranty..
Ameritron will not warranty the 811A tubes if it is evident that they were run hard. The plates are pretty thin and fragile and I have actually seen holes burned straight thru the plates of 811A's from operators running them too hard especially in AM service. It just kills them. My personal preference is for an amp that uses external anode ceramic tubes. In CB-speak they are called steel tubes even though they are NOT made of steel. That reminds me I need to get back on my little home brew amp project that uses a 3CX3000A7 tube. :D
  • @ heartbreaker3473:
