Ameritron AL 80B 10 meter mod.
Behind the band selector knob on the inside of the front panel is an enclosure under an inch thick. It contains the tuned-input circuit for each band. A green wire snakes out from a hole in the compartment's side, soldered to a ground lug. Cutting this wire will activate the 10-meter input circuit and make the "blank" band work.
I always thought you had to buy a ten meter board/module or something to get ameritrons online on 10/11. Is that just certain models?
