This is a “600Hd base unit”...using HG2879c pills.
Driven by a Stryker 955
problem...
I get feed back to the radio receive when I unkey and swr is in the 2.8-3 range on the radio face...verified with a meter as well. This is only on a.m.
*brand new amp...no reflect rf when it left the builder.
*antenna grounded with #10 copper to a ground rod at the base.
Things I’ve tried...
1. New lmr400 from the radio to the antenna (thought the amp might be to much for the rg8x I had in line.
2. Retuned the antenna with an analyzer to near perfection...swr between flat and 1.3 under all conditions even with the amp on.
3. Tried a different antenna...A99
No change with any of these.
Things I’m thinking about trying...
1.A fresh ground on all equipment to a second rod.
2. Pull the 955 from my truck and see if it does the same.
3. Try a small driver between the 955 and 6 pill...the builder tested it this way with about 250 pep drive.
4. Possibly run a dedicated 110 circuit just for the amp...I know it would be stretching it otherwise.
Any other ideas??
problem...
Any other ideas??
