years ago i had a 2-2290 one
Shot at 2008-10-23
worked as it should and had a low input swr.
You had to be there...dilithium crystal forced cooling system ?
thats the one .....i believe it had only 1 fan on one side blowing across the lower heatsink .Remind me funky, was that the model with Adams patented dilithium crystal forced cooling system? (now used on shuttle reentries) you know the one that allows the amp to run with zero temperature change in all climates.
Maybe it was the later versions he built, that he bought up motorola's whole stock of mrf 455's for.
Never seen that one before, thanks for posting it.This is the best one.
when you get where you want to be.............................
YouTube - CBRadioChat.com speaks with AMPOWER!
