A Winner has been selected for the 2025 Radioddity Cyber Monday giveaway! Click Here to see who won!
That is funny LOL. What are the power transistors with more gain that they are using? Can't tell from the video, haven't researched it. Never worked on a ALS-500, only the 600 model.
Ok I see here on the Youtube video description he adds this:
The second issue is mainly when PP100 transistors are used in place of 2SC2879 transistors. The amplifier has a large current spike. The PP100's have a lower base bias threshold, typically I measure around .51 volts or so, and high dc current gain at idle. The bias circuit has a very brief (a few milliseconds) spike of around .75 volts before it settles to operating bias levels. The PP100's also have a good bit more VHF gain. This causes the amplifier to momentarily oscillate upon relay closure.
I'm glad I have one of the older ones with the 2879's in my Jeep. That thing has been rock solid for me. That remote current issue is troubling, though...I use that!
I was laughing at the oscillating / Bias spike problem. Should never see such a thing from a production amplifier. Not funny for the end consumer, no, but funny as a tech to see that happening.
I never knew Ameritron used "PP100" outputs until now.
But I do know Ameritron is owned by "MFJ" now and that pretty much explains it all.
Take their most expensive amps... a 1 year warranty.. So they are not expecting, they are hoping your 5 thousand dollar linear lasts a year.
I get a 6 month warranty on all the tubes I use from my distributor in our guitar amps we manufacture.
I bought a new 300 watt mfj matchbox at the Dayton fest a few years ago. The metering never worked. Turned it in 3 days later, 8 month later I got it back. Exact unit, I etched it. And guess what. Just as phucked as when I got it. Still have it. And on top of it. The dummy load is 57 ohms... that's 14%!
I too have an older one with 2879's and use it with the ALS-500RC remote and it works fine. I tried it with the ARI-500 remote auto-band switch and it seems RF or something else occasionally will trip the amp into fault to where it was too aggravating to bother with it.
Seems like putting a simple fuse in line on the internal remote wires would be a good idea.
