Audio Compressor using AD SSM2167 (Speech Processor for more AAAAA-DEE-OHHH!!)
Michael M
May 17, 2019
20
13
13
57
Guys, I do not see any postings for Audio Compressors using AD SSM2167.
There are plenty of posts for the CB City International speech processor, which are unavailable. I used one back in the day...
Here we are 2025.... Just FYI, Assembled compressor boards, based on the Analog Devices SSM2167, are available on E-Bayz for <$7 by searching "ssm2167 module"
Ready for a new project for the new year??
Give it a try !
There are also postings on goob-tuber with folks demonstrating this board:
AD SSM2167 Datasheet:
Any experience you have, please share!
Interesting little board. Amazon has them too:
Might pick up a few for my next microphone victim.
Edit:
It has a noise gate too. Some of the Amazon comments say that it works best if the resistors for the compressor and noise gate are reversed. I wonder what it uses for negative feedback? Might be able to add a tone control.
Reactions: Cable Guy
Yep, I bought a few myself, Cable Guy
As Shade Tree noted, & M0NTV also found, R1 and R2 were misloaded on the boards he received: no compression was taking place as received off ebay! :-OO
So verify the values of R1 and R2:
R1(gate): 15K ohms for 2:1 of compression (or use a pot)
R2(comp): 1K ohm for a -48 dBV gate (knee) (or use a pot)
Let us know your results !
Michael
Yeah, I noticed that from the video you put up, but I don't care, I'll probably put both on a concentric stacked pot. I ordered mine from China, yeah it will take a while to arrive, but at about half the price of the Amazon listings, I don't care really. If they are legit, they will make a nice drop in addition to any radio. Thanks for pointing them out Michael.
Something I didn't think about, how to power this baby. It takes 3-5vdc. Rather than probe around for a usable source, I decided on this 7805 regulator.
And again, with it's supporting components.
And, a unit ready to go, sans shrink wrap.
The 7805 is capable of 1.5 amps current. It should be heatsinks if tasked to deliver. However, the board draw is so negligible it didn't even register 4ma on my supply during testing. Given the small power, I think the regulator will be fine without sinking.
I will install it today and let you know how it goes.
Nice one, cable guy! Crazy the size
I'm thinking of the same concept of the 7805 and dual-gang pot adjusting. My boards arrive at the end of the week.
Post what find once you get it going. It should be interesting to mess with.
Thanks,
Michael
I wasn't thinking when I first wired the pot with plain wire. I replaced the wires with a shielded cable due to rf feedback. The mic in and out i had already used shielded cable. Also, I added a toroid choke to the power wires. Once set, seems really stable. It has a lot of gain, so don't go crazy on the compression pot. I used a dual 50k because that's what I had on hand.
Came across a schematic of the SSM2166 with variable low (bass) an high (treble) gain controls + an input attenuator (pot). Credit goes to WA1QIX
