Be careful of wood stoves !
Sonwatcher
3,402
26
48
Colorado
Today the guy I work with and I were driving into a small town and saw a house on fire. The fire was surrounding the stove pipe that came out of the garage. We were the first ones there so we bailed out and ran to the house. My friend tried to kick the front door in but it wouldn't budge. We heard a dog barking. He beat on the door in case someone was inside but no answer. I ran around back and kicked the back door in and the smoke just bellowed out. But the dog had quit barking. The fire was in the house as well as the garage. It completely burnt. I am hoping no one was inside as I would feel horrible having tried but not able to reach them . Please be careful when leaving a wood stove going during the day.
i live in n.w.oregon in a small town where our electricty is run by a PUD. my highest bill for the year was 150$ one month in december. your story and our cheap electricty rates is why i dont got a wood stove. me and my wife both work and i do have a dog to. hope no one was in the house also. poor dog. i wouldnt mind having a wood stove for back up but your right. be carefull with the wood stoves out there.
I just found out no one was home but they did lose 1 dog and 4 cats . The smoke was horrible with all the vinyl siding and such a blaze .
Glad noone was home to get hurt, to bad for the dog,,,,,,,,,and that is all I have to say about that
Wood stoves can be safe if you follow some basic rules and use common sense.
First problem with them is the installation, some folks don't do it right, use the wrong type of stove pipe, and fail to properly fire proof around it.
Another problem is people fail to have them properly cleaned every season, no matter what type of wood you burn, it all leaves deposits inside the chimney that needs to be cleaned out, or you risk a chimney fire, and that's what probably happened in this situation.
If you spend the money and buy a good quality stove, good quality and approved triple wall smoke pipe, install it per modern fire and building codes, burn only well seasoned hard woods, (no treated lumber, woods containing a lot of sap, or Dura-Flame logs) and have it professionally cleaned at least every two years, then the chances of it starting a house fire are very low.
Another thing you all should have is a C0 detector in you home. If you have a total electric home, that being electric heat or heat pump, electric hot water, and stove, no fireplace or other apparatus that burns a fossil fuel, and no garage attached to the house, you really don't need one. However, if you have any type of apparatus that does burn any type of fossil fuel, a C0 detector is a must. Don't be cheap and buy those combination units that are both a smoke and Co detector, smoke detectors belong on the ceiling, Co detectors belong close to the floor. For the best protection they should be two separate units. A Co detector should never be mounted any higher than a light switch, and not in the same room as your mechanical equipment (furnace, boiler, hot water heater) or in the kitchen, you will get false alarms when they are placed in those locations. Install one on the lowest living floor, if you have a two (or more) story house, then add a second unit on the second living floor.
(a living floor being, any level of your home where you are likely to spend a lot of time, and have the opportunity to fall asleep somewhere on that level of the home) In other words, if it's an unfinished basement that is only used for storage or a work shop, then you don't want to put one there. If it's a finished basement with a TV, and furniture then you want one down there.
Just some helpful hints from your friendly local professional fire fighter....
I'm willing to bet that they (the homeowners) didn't have the building ispector nor the fire marshall check out the stove before they started using it.
Thank God no one was home!
If the fire was around the pipe then it sounds to me as if the stove was not so much the issue as it was the installation of it and the pipe. People have no idea just how hot a stove pipe can get and if installed improperly,ie. too close to combustables, then it can be disastrous. I have been burning wood in a combination oil/wood furnace for the last 20 years in my own home and for years before that at my parents. It takes very little effort but a bit of understanding to know how to properly burn wood. Air flow and pipe temperature means a lot.
I grew up with wood heat but our heaters always vented via a brick chimney and I have installed vents through walls and you have to use either a double or triple wall insulating through pipe depending on the materials it passes through.
And all vents need to have a damper valve installed to prevent the heater from running away or in other words venting out of control.
Nothing like going to school every winter day smelling like oak or ash.
