Browning Golden Eagle Mark III and signal generator
Crambone
I Support WorldwideDX.com!
Jan 22, 2019
563
175
53
58
Can the receiver be tested alone without hooking up the Transmitter to it? I want to put a 27.???Mhz 30%modulated signal into it for testing?
Shameless self promotion:
https://www.ebay.com/itm/1145912749...d=link&campid=5336136228&toolid=20001&mkevt=1
Or you could just find an 8-pin "octal" plug. Add a jumper wire from pin 4 to pin 5. A second jumper wire goes from pin 7 to pin 8.
This is really all you're buying in the overpriced fleabay listing. An 8-pin plug with two jumper wires installed.
The receiver is perfectly happy to operate alone, so long as those two connections get made to the transmitter socket on the rear.
