I've got a Mark III Transmitter, everything works as it should except when the meter switch is in the "MOD" position. When the switch is set to "MOD", the meter deflects full scale, and the radio will only transmit a carrier, no audio. This only happens when on AM, if the radio is set to usb/lsb, the meter behaves normally even while in the "MOD" position. Also, if the meter switch is in any other position, the radio transmits (and modulates) perfectly.
I have checked the diode (sr4), the cap (c55) and the resistor (r53), all of which test good. With the diode disconnected, (no connection from meter to modulation transformer), the meter still pegs, and I am reading about 270V across the leads that feed the meter. There are no *obvious* shorts that I can tell. According to the schematic, with the diode disconnected, the meter circuitry should be dead (when in the mod position), so I cannot figure out why there is HV on the circuit. Also checked all the electrolytics, which are ok as well... Any ideas?
