Can someone tell me what this amp is worth?
cjruger
219
17
I was told it is a palomar 250 watt. It has 2 sd1446 pills inside. It was bought new and never used around 10 years ago or more. Is that the proper wattage and does it have an automatic sideband switch inside? The guy wants 75$ for it.
i went to google and type in palomar 250 watt and just go through and read man when in doubt go to google remember google is your friend
If you can find them for $50 buy it up. Just a cheap little amp. Will do closer to maybe 180-200W pep. But what you have to remember is, the 1446 transistor is now going for $35-40 if you have to replace them. If its new never used, the transistors are worth that.
Looks just like my ShootingStar. It has 2X1446's in it. Does about 175 PEP @ 13.8 Volts. :confused1:
Those black face Palomar 250 and 300 amps are cheap class C throw away amps. Used and working 50-75 is fair. Brand new they are 109-149 depending on where you look. The best of the breed are the blue face Palomar 250's, they are class AB with some filtering.
Palomar Elite 250 Linear Amplifier, DNJ Radio
The number on the front is more of a model number, not wattage number. As stated, those finals are getting expensive. I used to buy the Elite 300's for 48 bucks each by the case, I could double my money easy in 6 weeks.
What are the input tuning figures on the AMP you linked? Is that a blue faced one from DNJ, looks black to me, but I'm color blind.
Thanks.
