CB - Computer Interface
DTB Radio
Well-Known Member
Sep 14, 2005
1,082
192
Carlisle, PA. USA
www.dtbradio.com
Some years ago, I put together an interface using an MS-DOS-based computer to control the channels on an old GE CB (just happen to be the same one I used in my Spectrum Analyzer project). I've gotten alot of emails for details on the project, so I've posted the schematic. Basically the computer controls up to 8 programming lines of the PLL chip. The software end can be almost anything from rudimentary hi-lo single line control, to sophisticated split-frequency programming with lots of memory channels. It would be possible to set up a rotating frequency plan that keeps changing the frequency to a new one every time you key, allowing VERY hard-to-follow conversations.
The software I wrote allows basic 40-channel control with split-freq operation, as well extra channel control for radios like the 148, etc including split frequency ability.
Reactions: AudioShockwav
I have a 959 that I'd like to use as a "project " like this possibly...will this overcome the "drift" or is this something that will still be present?
and how much ya chargin?hehe
This system simply controls the programming of the PLL chip, and monitors the transmit pin of the mic jack to control split-frequency operation.
By the way, I finally uploaded the correct schematic. Someone pointed out that the one on the site still showed 7407's, instead of teh 7406 that should have been shown.
Found a potential bug in the software, so it will be unavailable for the moment. If you are familiar with Windows IO operations and file operations in Visual Basic or other programming language, you can write your own. I'll be happy to provide the layout of the data files and how to read them.
OK, this baby is DONE!! I updated the help file with the new graphics from the program screen, and added a bank of 10 memory slots, each of which holds a complete channel AND frequency group.
NOW tell me what you think!
Click here for the updated setup files
I plan on offering the entire system, including the software and schematics, on a CD-ROM very soon.
This is an ancient thread, I know, but I wanted to post a quick update. The system discussed is very outdated, and the links no longer work as I've removed the associated files from the dtbradio.com website. I had updated the system with USB support, but due to a break-in at the shop in January of 2023 during which our computer was stolen (including the backup file drive) the files are forever lost. There are tentative plans for a replacement system, USB-based, using the same data file format, but due to time constraints the project may not happen for some time if at all.
