If I were to use my mobile Cobra 29 as a base station, could anyone recommend the antenna? I was thinking of aquiring the interceptor 10k as people seem to think it works well. Could anyone tell me if this antenna would work well for a Cobra cb?
Oilpatch197 said:King Mudduck said:Dude all you need is a Imax 2000,saty away from the Antron 99. Put it up 36 feet and you can talk just as good as the higher priced antenas........DONT BELEAVE THE HYPE! I have the same setup and with a 50 watt radio i talk all over the country all the time.
285 western NC and im back quite!
No no no! Lets be true CB'ers here, the antenna has nothing to do with it, all he needs is 3 Kilowatts out of a brick, the amp is everything you know!My Dosey meters are very accurate, cause' they're Dosey's!
Imax 2000 would probably work, just clamp it to some steel conduit, some RG-58, or whatever the Radioshack guy sells you. Also you need a really good SWR meter, expect to spend $15 on the swr meter, if your in a pinch, time to dumpster dive!.
The Citizens Band radio service is not very similar to Amateur Radio. Like cell phones and FRS radio, CB uses RF to facilitate communications. That's were the similarity to ham radio ends. CB has not required a license for many years. When it did, no testing was involved. It requires no technical knowledge. When we equate ham radio with CB, we are minimizing our accomplishments.
Ok all joking aside: If someone has a technical interest in radio, wants to chase DX or experiment with antennas, he would enjoy Amateur radio. If this person's first involvement with radio is with CB radio, we should encourage him to become a ham, not run him off with petty bickering. It's only by helping those with a real interest that we can insure we will have good operators instead of a bunch of lids who think name calling and arguing is acceptable behavior in amateur radio.
You've all seen the website "trailer trash" http://www.missouritrailertrash.com/
I'm wondering if KC2OST would be intrested making a website, "CB trash" and start posting pictures of trashy base stations.![]()
