CB Re-caping
Philomath
Sep 5, 2016
4
4
13
69
Melbourne Australia
Hi there folks, I hope you are all well. I have a Capacitor question. I'm not a tech, Just a tinkerer.
I plan on re-caping my Cobra 148gtl and my Uniden Washington. Upon reading the capacitor list for these radios, I see that the Cobra has around 12x .47uf capacitors with 4 different voltages ranging from 10 to 50 volts and other values with different voltages.
My question is.
Can I just simplify the parts list by just using all 35volts or higher for all capacitors?
Thanks in advance for any advice.
Best regards to all,
Walt.
Thats what I do. I just order 10 to 50 or so of each at a time from Mouser as needed. Some get used more than others. It helps keep my storage bin space to a minimum. Keep in mind that some are rated for 50v.
Also 0.47uf is as small as I have ever ordered, I havnt seen much difference using them where a 0.1uf or 0.22uf electrolytic would go, these are usualy for passing audio or, absorbung the "Pop" spike in a switched circuit. Youll be fine
Reactions: brandon7861
Or you could just buy a complete kit from a place like Klondike Mikes.
Heck yeah, These are great if you're focusing on one radio at a time and bringing back original performance and quality.
But, if you want to experiment with different enhancements or characteristics in the radio or just have multiple radios to go through, bulk is a better option. Just so you have the stuff on hand.
For now ordering from Mike will be the best option.
The most important things now are:
"Time" , Don't rush, double check before and after each cap, you shouldn't have to pull or twist. A little wiggle while heating will tell you if you're on the right one...
"Good smaller tip soldering iron"
, I picked one up for around $30, you don't have to go crazy on features, but picking a known brand name is a plus. It will last for years.
" Iron resting spot" , you'll be focused on the repair using both hands, and the iron needs to be in a handy, known, accessable spot.
"Desoldering Tools"
I recommend the solder remover kit from (please forgive me) Harbor Freight, it's only about $13 and comes with 3 solder remover pumps and 2 rolls of solder wick. The pumps can be disassembled and cleaned too. I still use the one I got years ago.
Once you get the feel for it, you'll want to upgrade tools and, find more radios to repair.....
Get to it, and tell us how it comes out!
My question is.
Walt.
There are two pieces of advice I could give you. When you get ready to replace the electrolytic caps, take a black marker (or any color) and put a mark or dot on the top of the cap towards the front of the cap that's facing towards the front of the radio. Do this to every cap before you start to de-solder them. That way when you install the new cap, you can use the old cap with the mark to verify which hole in the pcb is for the negative lead. Sometimes the pcb hole has the positive polarity mis-marked. I've also found a 1uf 50v cap with the positive lead to ground on a radio, and that's the way it was intended from the factory. Even though it looked like I was installing the new cap wrong, but with the mark on the old cap, I knew it was correct. Plus once your done recapping, you can check every capacitor and if you find one with the mark on it, you know you missed that one.
Always replace the electrolytic cap with the same value. If it's 470uf, then install another 470uf. You can always go higher in voltage rating, but be aware that the higher the voltage rating, the larger the cap might be physically. Sometimes due to the tight fitting of parts, you can't replace a 16v cap with a 35v, because the 35v is physically to big to fit.
Reactions: MKwrench
He is also a forum member.
