Hello HH:
Ok I have a little more time here to reply.
The MaCo 5 Element Beam will be modified, removing the stock elements, and install a Insulated Boom to Element Brackets holding the new shorter elements. I have made several of these insulated brackets for other applications, in amateur (20 meters beams) and commercial (VHF Beams) antennas.
The 5 elements will be the Reflector and Directors, and I will make the driven element, so that accounts for the 6 elements.
www.uksmg.org/yagi.htm
As the specs say for this yagi beam a full 10dBd Gain. Now thas a lot of real world gain. So if you feed the antenna with 100 watts of power from the radio you will see a 1000 watts of Effective radiated Power (ERP) going out. That ought to be able to snag a few stations on 6 meters when the conditions are right. Then you could put a 6 meter Interceptor 10K on top of the beam.
The ARRL will no dough will want to have your picture on the front of QST Magazine, with the antennas in that back ground with some Babe hanging all over you. Men will fear you, and women will adore you. You can buy 6 copies for your Mother, hehehehehehe......
The bad thing is that Moleculo will want the 4 element, 17 foot boom version also.
Jay in the Mojave
www.a1antennas.com <img src=http://users.joplin.com/dutch64804/posticon44.gif ALT=":44">
</p>
