If you are referring to freecell's posts, be careful, they are not completely accurate. There is some good info in there, but can you tell the difference between the fact and the fiction? For example, he refers to a so called "undocumented opinion", the so called opinion he is referring to is actually well documented by reputable, and even engineering sources.
