Cobra 142 GTL
Try waiting longer, even if it seems to disappear. It might be there is some timeout where the server gives up, I'm not sure on that. If the problem persists, drop one of the mods a message.
Ok. Thanks for that tip.
We know the sams was wrong with 5v, no need to send that. I was only interested in the order in which things are aligned. Get them in the wrong order and one messes up the other. No need to attach anything, I'll just explain.
When aligning the oscillators, be sure to align USB first, then LSB, then AM. It must be done in that order.
Consider the 11MHz oscillator. CT3 will affect the frequency in all modes, but in USB, it is the only adjustment. If you were to align LSB, then go do USB, that would throw off LSB. Likewise at the 7.8MHz oscillator. If you key up and align AM TX and then go turn CT1 afterwards, the AM TX is off again. Just be sure you are doing things in the right order!
Ive definitely experienced this. Ibstay in the order as listed in the svc manuals.
Reactions: brandon7861
This is going to sound rude, but it is not intended that way. If you have done this 5 times, the oscillators should not be off by this much. The tripler is off by a whole kHz, gotta wonder why after round 5.
It makes me think that there might be a worn out trimmer or pot somewhere. My daily driver is a washington (same board as the 142) and the trimmers are toast. Still haven't bought any more through hole trimmers, one of these days. Anyhow, I can lightly tap on the chassis and it changes frequency. Do you see sudden jumps in frequency when touching the trim caps or tapping the radio? Does it move more than a few Hz when it gets bounced around a little? Does turning the clarifier when listening to a SSB tone cause erratic tone shifts or does it slide smooth?
1000023330-jpg.75557
You should get that sonybond glue out of there. It absorbs moisture from the air and turns corrosive and eats legs off parts.
Reactions: vswr
I can take a look at your settings but if you're conection is slow and the file is large it may be taking a while to load.
Thanks Jeff. Yeah it starts to upload and at around 15% it just stops. I can upload pics no problem. Pdf is another matter.
Im working at it not that easy. Its horrible andbI have no idea why they just didnt use rtv.
For the glue I use a little bit of acetone on a q-tip and apply it directly to the glue. Helps soften it up a bit. Nail polish remover is usually just acetone so you may already have some if you have an XYL in the house. I strongly recommend using it where you can vent the fumes.
I'll also pull parts if it looks like the glue got underneath them. If the glue hasn't eaten a component lead I'll sand off the black crud it leaves and tin the lead before reinstalling the part.
In any case, get as much of that glue out of the radio as you can. Even if it's not the problem today, it will be at some point.
Don't see anything rude there. Lol. I'll bounce it around and see. I did notice a warble in tone when shifting channels and clarifier. The reason why I did this about 5 times is because I had a helluva time with the clarifier when it was unlocked and putting all my money on the 5 volts at L13, then trying to align it so as to get that 10k issue fixed. I was able to get a faint signal by winging it but it wasnt lining up enough to make any real sense. Once I set it straight, i got some stability. It was pissing me off enough for me to take my 10lb sledge to it! But... i didnt. Lol. Only strong signal comes about when its 10k off and even after I put the clarifier back to stock, it still slides over way too much to be normal. Im pretty sure that some other parts were removed and/or put in coils or varactors or removal of disc caps. I cant see anything though. I will have to go part by part through the schematic. Id like to get a factory service manual or a schematic that isnt a sams job. I do see a cut run underneath the 2 crystals that has a disc cap installed. Looks like another hack job. Same as that electrolytic cap from the stack to a resistor that seems to do nothing.
