Cobra 142GTL Intermittent AM Transmit
Aug 1, 2025
6
4
13
58
South Louisiana
Hey Guys,
Thanks for your continued support. Purchased a Cobra 142GTL from eBay (1st Red Flag!) Good radio, but has had some work done in the past (2nd Red Flag). Talked with a bud locally on AM and he mentioned to me I was "Choppy" & "Intermittent". Changed the mic and still had the same issue. Switched radios and put the 142 aside. Well, got it on the desk and did the Clarifier Mod. While tuning the radio, I noticed what he was talking about. It'll key up and hold steady on the dead key and then is leaks off, falls off completely, comes back to 2W (preset dead key), and repeats that cycle until I let off the mic. I checked for loose solder joints around the driver and final with no avail. It doesn't react this way on SSB and I've made many contacts on SSB in the past. Only on AM. I haven't checked any voltages (planning) but have been searching for answers here with no luck to my issue. Radio has NOT been recapped. It seems there are some caps that have been replaced previously. There's also been some work done in the power supply area also the the power cord is only about 18in long. I'm baffled as to why.
Get a can of "duster" from the office-supply store. Key the mike until the transmit fails, then turn the can of duster upside-down. Now squirt the final transistor with the can inverted. This will spew liquid onto the final transistor and chill it severely.
If the wattmeter jumps back up immediately, the final has a thermal intermittent failure inside.
If you press the can's valve only partway you can direct the stream or better, just dribble onto the final without splashing too much onto surrounding parts.
Used to have a transistor we held onto after a repair. Hook the component tracer across its base and emitter pins and you would see the normal dog-leg pattern. Hold the soldering iron against it on the rear and the trace would flatline. Pop it with some chiller and it would come right back.
Every time.
The fact that its fine on SSB pretty much rules out all of the RF side of the transmitter including the final/driver. I would look closely at the AM regulator circuit as that's the most likely failure point. When the radio is in SSB mode, the AM regulator is completely bypassed and the driver/final are tied directly to the main 12-volt rail. In AM mode, the driver/final are powered through the AM regulator circuit. The fading out and coming back point to a thermal issue, and its likely going to be the main regulator transistor (TR34), which has to handle all of the transmit current in AM mode. As suggested above by Nomad, hitting a thermally-failing part when its in failure mode with some kind of freeze spray should tell pretty quickly if that is the case or not.
There's nothing sacred about the 2SC1419 part number. A whole slew of audio transistors will take its place. We use TIP41. It has a higher current rating, and it's pretty generic.
Thanks to you mentioning that the other year, it made life easier when I would go replace them in a couple of my 146 GTL radios as well as the TRC-465 radios.
OK...got back on this project and remembered when I received this radio, there were globs of heat sink juice all around the AM Reg. I sat there with a Q-Tip and cleaned all the excess off. After revisiting, it looks this was a problem before. The markings don't match (2C1419) and not sure if this is a knock-off. I also marked all of the cracked cores with a RED dot. This is still a good SSB talker for sure. Now, I'm planning to source the TIP41 replacement as suggested and go from there. I want to make sure I get a proper one and not a Chinese fake, so any suggestions would be greatly appreciated. I'm leaning towards DigiKey but you guys know way more than I do. Thanks.
I'd be wary of "2SC" parts as number reuse is rampant. Talked to Digikey engineers about it and they recommend parametric matching rather than number matching.
As Nomad said, TIP41 will do, as will many others. TO220 are easy, universal B-C-E, unlike the TO92 types.
I always use goop and mica insulators.... avoid the silly-cone stuff, the transfer just isn't there for a linear part. Switchers, OK.
As for leaning Digikey, I've had my commercial account there since the 1990's with zero problems. I have used Mouser and for certain things (like buying half a crate of power transistors), can be cheaper, but onsey-twosey, go Digikey(y)
SK3893 is rated 40 Watts, 7 Amps and 60 Volts. Should be stout enough, but only if installed correctly. The "SK" series parts were a line of cross-reference equivalents like the NTE products. Was originated by RCA in the sixties, and sold to Thompson in the RCA breakup of the early 80s. Had to go to Data Sheet Archive to find it. And if I was at work, there's likely a SK catalog and cross-reference book somewhere.
Hopefully this transistor is the problem and not the mode selector switch.
Hey guys! Success is in the air! You guys rock! Contacted a good friend who's done some repairs for me and was directed to ICA Manufacturing for the TIP41. Once I received it, I pulled the old one and tested in my tester. It showed a hfe=27. I tested the new on and the hfe=54. Much better. I installed it and tested the dead key and it was stable on my 2W carrier (preset). I made a contact with a local on 2 different mics and all was much better. No intermittent interactions. Again, you guys are awesome and thanks for your knowledge and patience in the matter. The radio world is in a much better place knowing you all are here to keep it alive3 and teach us at the same time. Happy Holidays and 73. Creole Kid
