Cobra 148 Gtl
nicky
May 9, 2018
31
16
18
81
I just recently bought a Cobra 148 GTL and there's a rotary knob on the right side of the radio and I have IMG_2121.jpg no idea what it's for.
Oh, ok - thought maybe you had a photo - wired the pot to the main board? Or left open and dangling like they removed a board? (I'm thinking ECHO but thats' me...)
ECHO would also have a "click" - like power on/off and volume knob - so if it doesn't then it's certainly something else...
Thank you!
:+> Andy <+:
Reactions: nicky
Thank you!
:+> Andy <+:
It does have an on/off click just like a volume control. I guess I'll find out when I get it powered up.
Thank you!
Here are some photos of the switch/pot that has been added. Maybe it shows enough to tell what it is ?
:+> Andy <+:
That's echo...
The long IC in there, I believe, is the "Bucket Brigade" - lots of other support parts though to add to this mystery - so I guess it's not solved yet...
Otherwise it looks pretty clean - I'd like to say you gotta keeper - but then ...
Does it work?
:+> Andy <+:
Reactions: kaos513 and nicky
I have had it hooked to a power supply and it powers up and all channels and lights work but I don't have an antenna yet. I've been busy with a honey-do-list.
I'm taking it to a guy I contacted in Warren Ohio that works on them to have it checked.I will tell the rest of the story when I pick it up.
James
I've got my fingers crossed that it's ok but time will tell.:rolleyes:
The technical term is "Charge Coupled Device", or "CCD".
It behaves like a row of electron buckets,so to speak. It has a long string of capacitors, each with a pair of switch transistors. One feeding into it, the other one feeding out. Each pulse of a digital input, called the "clock" will cause each bucket to dump its stored voltage into the next one, and accept the voltage dumped into it from the previous one in line.
To use it for a voice echo, you feed your audio into the first bucket via the analog input pin. The output from the last bucket gets fed back into the input pin. The audio is a string of analog "snapshot" samples of analog voltage you feed into it. The speed of the echo changes when you change the frequency of the clock pulses.
The chip was developed as an image sensor. Each capacitor "bucket" would get charged in proportion to the intensity of light that falls on it. After you close the shutter, you pulse the clock input to get all those analog pixel voltages out of it.
But if you put it inside an opaque black plastic package, nobody will know that it's light sensitive.
