I gotta 148gtl made in 1996 with a rci8719 chip in it. Will it mod the same (channels) as a regular 8719??? Heard someone say they didn't. Thanks, Hooty :roll:
as far as I know hooty ? it should work fine and very easily done ....it helps to have the tools of the trade for accuracy but it's still pretty much cut and dry , this is one of many you can do and you can also look through out the Net for more ,channel mod good luck to you.
I found that pin 10 to ground = blowed chip....I thought that's what I had read somewhere before but couldn't remember...Anyway, I will replace with MB8719 and all should be well!!!
The American Radio Relay League (ARRL) is the national association for amateur radio, connecting hams around the U.S. with news, information and resources.
