Cobra 148GTL VS. Galaxy DX-949
CTStallion
196
21
Connecticut
"Ladies & Gentlemen...... let's get ready to r*mble...."
In this corner, we have the returning heavyweight AM/SSB champion of the world, a (1990's?) side mic Cobra 148GTL. TX section consists of a 2SC2166 driving a 2SC1969. Mods include: resistor mods for increased audio output on TX, volted final, 2SC2999 RX transistor, Schottky diodes for NB and AM product detector, TX and RX alignments. Power output: AM DK 4 watts peaking near 20 under modulation; 18W SSB PEP 2 tone audio test.
And, in the opposite corner, we have a 2005, made in Malaysia, Galaxy DX-949 which has upgraded audio and regulator transistors, heat-sinked 2SC2166 driving dual 2SC1969 finals, NPC-RC mod (on AM), 2SC2999 rX transistor, Schottky diodes for NB and AM product detector, 'Super Ears' RX mod. Power output (on High Power): AM DK 8 watts peaking near 25 under modulation; 30W SSB PEP 2 tone audio test.
AM Transmit Audio quality and modulation (FACTORY STOCK mics): with OEM coffin style dynamic stock microphone the 148 GTL is clear, crisp, articulate & LOUD. The stock mic included with the 949 however (especially on a factory stock radio) makes the audio slightly 'mushy'. Forward swing however, especially when the variable RF power is decreased, makes the 949 the better choice for running an external amplifier; you can turn that puppy down to 1/2 watt if you choose. But, for fidelity, articulation, brilliance, and frequency response to the male and female voice(s), +1 point for the 148 with the factory stock mike.
AM Transmit Audio quality with (various) amplified mics including D104, 575-M6, Turner +3, 1104C, and Cobra Power Mics: The Galaxy (no doubt due to the NPC-RC mod) begins to lead the Cobra. +1 point Galaxy 949.
SSB TX Signal: Every single DX-949 and DX-959 ever obtained, new or used, required alignment of BOTH the USB and LSB freq slugs to get them on the proper freq. AND, the 949/959 chassis apparently noticeably changes frequency in response to ambient temperature, requiring an open clarifier mod in order to get yourself back on freq EVEN AFTER ALIGNMENT FROM THE FACTORY, or via a technician. This is especially troublesome if you live (like me) in the Northeast corner, and want to use a rig in the mobile. During the winter, the rig gets REAL cold at night, then you fire up the engine, turn on the heat, and your 949 changes freq (substantially) as the cabin/radio heats up. W/O open clarifier, you couldn't work SSB until your rig came up to temperature. 148 on the other hand is much more robust and temperature tolerant. Also, the tuning ferrite tuning slugs are much sturdier and less subject to shock/vibration. You could even melt wax into the 949's to stabilize them after alignment and they (eventually) would still (slowly) lose their alignment. +1 for the Cobra here.
SSB Receive: Both before and after upgrades, the 148GTL has a much more pleasing AGC response. Better signal-to-noise and adjacent channel rejection. Hook this puppy up to a filtered (or DSP) external speaker and you get better ears than ANY Export and even most ham rigs. A modification was even made to the 949 to slow the AGC on receive and it still didn't compare to the 148. With the RX modifications made the 949 might even have a slight edge in sensitivity/gain in the receiver, but there never was a station I could hear on the 949 that I couldn't on the 148. The only redeeming factor of the Galaxy is the GNF (Galaxy Noise Filter). While the GNF is something that most folks find useless, I did find a time where it came in handy. I was using a wireless keyboard/mouse setup in the shack that gave me RF on Channel 15. The Cobra had no way to attenuate the noise acceptably. The GNF all but removed it, but at the sacrifice of clarity/intelligiblity of the received audio. Other than that one freak incident on that one channel, both base and mobile, the Cobra is a better SSB receiver. Score +1 point for the 148.
Raw AM/SSB TX POWER: Factory variable output power, plus the ease (relative) to dual final and/or MOSFET upgradability, give the clear edge to the DX-949. +1 Galaxy.
AM Receive Sensitivity: Well, this too will be a somewhat 'unfair' comparision as the Super Ears mod was made to the DX-949. Both receivers have 2SC2999's and Schottky diodes, but the 949 can pull an S1 signal up to an S5 or S6 with little (if any) noise when Super Ears is activated. So, give the 949 it's point on AM. +1 Galaxy.
AM Receive Selectivity / Adjacent Channel (splash) Rejection: +1 for the Cobra. I've got a couple of locals who run power, and one KW mobile who likes to shoot skip on channel 6 AM. I'd better not be using the 949 (especially with Super Ears activated) when he keys up or my receiver is toast. Also, even w/o any rx mods, the 148 is less subject to rx overload. +1 Cobra.
Looks/Appearance: Beauty is in the eye of the beholder. Both rigs have the approximate same dimensions. The Cobra 148 is chrome faced and the Galaxy 949 is flat black. I find the meter on the 949 more functional and more pleasing to the eye(s). The 949 has variable dimmer control whereas the 148 is merely a bright/dim switch. I like them BOTH equally; but will give neither rig any points due to the subjective nature of this category.
Functionality in the Mobile Environment: Not including the dual function knobs (knob within a knob), there are 6 knobs + 1 channel selector + 4 switches on the 148 vs. 7 knobs + 1 channel selector + 5 switches on the 949. The 148 is much easier to use in a mobile environment, especially in the dark or if switching back & forth between AM/USB/LSB, whereas one must take his/her eyes off the road to navigate the face of the 949. +1 for the Cobra for ease of use.
Features: The 949 has lots of features lacking on the 148 including: Galaxy Noise Filter, Variable Talkback, External Freq Counter jack on the rear, Modulation Meter, Medium Tone position, Switchable Roger Beep, variable RF output power, and SWR measuring w/o the need to calibrate. 949 easily scores +1 over the Cobra for added features.
Dislikes/Negatives: There's really nothing I don't like about either radio, so I'm not gonna deduct points from either. If I had to nitpick, I'd say I really don't like the side mic jacks on either radio (solved by recent editions of the 148 and DX-979 rigs), I don't like the 5 pin mic on the 148 (I had to use an adapter for all my 4 pin wired power mics to run them on the 148), the GNF feature of the 949 is barely useful, the 949 has SSB stability issues which may only be addressed by getting inside of the radio. Finally, the most SSB power I was ever able to get out of a 148 (or Grant XL or TR-296) was 25W PEP SSB, whereas (with dual finals mod) I've gotten 949 and 959's upwards of 45W PEP SSB, and MORE than 25W on a single final. The negatives are really MINOR with both of these 'classics', so there's no deductions for either chassis.
Final Score: Cobra 148GTL = 5 Points; Galaxy DX-949 = 4 Points.
The WINNER, and still "Heavyweight Champion of the CB World".... the Cobra 148GTL.
Someday, (when I've gotten my hands on the NEW front mike mounted 148GTL and a new Galaxy DX-979) I hope to do another comparision.... BUT, based on what I've read, seen and researched, I'm quite sure the winner in that fight will be Galaxy.
In the meantime, I've got a 2003 Galaxy DX-919 AM only that's been worked to pit up against an equally vintaged (albeit MOSFET'ed) Cobra 29 LTD Classic to compare in a later writing.
Till then, I'd be real interested in anybody's comparisons, especially between newer radios, (i.e. NEW DX-979 vs NEW 148's). (y)
very informative and nicely done sir ;)
id love to hear your opinion/results comparing your side mic 148 to your 2950dx on 11 meters as far as tx and rx go . i know its not exactly fair given the rci also has 10 and 12 meter capability , more power and more features . im mainly interested in what comes out of my speaker when im rx'ing and what comes out my contacts speaker when im tx'ing .
the new front mic 148 are pretty much considered as junk on SSB except by shops wanting to sell them .
COBRA 148GTL NEW CHINA VERSION
Well I guess there are GOOD batches & BAD batches but I have had ZERO issues with my COBRA 148GTL(China version).Nobody says anything about SSB being off frequency or anything EXCEPT how good the radio sounds. Almost every review page I have read says something NEGATIVE about this radio but I can't find fault in mine? Guess I got a good one or the previous owner had it worked on prior to me becoming the second owner? Other than being PEAKED it has ZERO mods(4 watts dead key & 18 watts AM "PEP" & 20 watts out on SSB)doing a GREAT job for me into a 102" stainless steel whip on the right rear of my 2007 DODGE 1500 "QUAD CAB" with a "HEMI".Maybe the HEMI is HELPING out some? hahahehe }:>) (y)
73,
SIX-SHOOTER
Invalid comparison. Radios were modified.
The ONLY valid comparison would be BOTH radios, factory stock, out of the box with no mods... then I will believe a comparison.
is it ok if i disagree ?
nobody remotely interested in really enjoying the cb hobby is going to run a stock 4 watt am legal cb radio . most radios can easily do 4-6 times that output , or more , and there is no reason to not maximize their performance .
just keep it clean and on frequency (y)
Reactions: 2 people
Why would that be the only VALID comparison with stock radios?
It is well known the galaxy needs alignment from the factory. Nothing new there.
Mod both chassis types with good, receive and transmit mods, then compare them.
This shows that after all upgrades and mods which radio will perform the best compared to the other.
I have a few 959's. with all upgrades except NPC, the audio and regulator chips have been upgraded. channel mods done with a board not the wire and switch trick.
Compared to the cobra 2000, basically same as the 148 with a few different circuits, hands down the cobra is the better rig.
The 959 does do better on power out PEP, the cobra 2000 is stable as a rock, even with clarifier mod done on the 959 still have to tweak it to stay on freq.
I think IMO that the comparison is dead on based on my experiences with both chassis.
Well, one radio modded by one person, could sound different than mods by another. My 949 will blow away a Cobra. Then.. the same Cobra could blow away my 949 if modded different.
You could take a Honda Accord and make it outperform a Ferrari. Folks would then say the Accord is better and post their findings.
See what I'm saying?
This is an unfair comparison. Compare BOTH radios out of the box.
The 148 has one very important advantage over the 959. And if you are a SSBer; it is distinct advantage at that. The 148 - along with only a few CB's and Export radios - have very little drift on SSB. The 959 does drift like a boat on SSB. Try aligning one sometime - it is a real pain and takes some real patience to make it right. Been there - done that. Even when aligned, the 959 will still drift until warm and stabilized after ten minutes or so. Colder weather with the 959 is a comedy of drifting errors. There is mod to make this right with the 959 at this time. The Cobra takes a very important/pivotal advantage here - IMO.
SSB Advantage - Cobra . . .
Now for AM - with both having an NPC mod - then that might be the real contest here. If both radios have been aligned first - well then - that would be an important qualifier.
AM Modulation Advantage - Neither
When it comes to adding frequencies, there is a little difference. They both need a Viagra board for smooth extra channel transition.
Frequency Modification Advantage - Neither
The roger beep, talkback, and freq counter jack perks goes to the 959 for those who need these additions.
Accessory Advantage - Galaxy
Haven't seen a radio yet that out of the box didn't need to be aligned to a certain degree. The 959 most of all. The 959's I checked were in sore need of a complete alignment. The Cobras were fairly close . . .
Stability Advantage - Cobra . . .
The 959 might have a power output advantage if it is a dual final or MOSFET radio. But that becomes moot when a small linear is being used with either radio. That would equal out the power debate portion - anyway.
Output Power Advantage - Galaxy w/dual final or single MOSFET
The receive on either radio is excellent. After aligning a few 959's and a bunch of 148's, I would say that they both benefit from receive mods as well. The 959 may have slightly better receive audio response, but the sensitivity of both radios sounds about the same to me. But for the 959, this is highly dependent if the radio's receive is in a fair state of tune.
Receive Advantage - Neither
EDIT: the 949 and the 959 use the same alignments procedure and specifications. It is basically the same radio. I don't consider the Cobra 148 GTL "NightWatch/SoundTracker" version of that radio a part of this comparison either. That dog just don't hunt.
Honda accord outperform a Ferrari? That would be fun to watch.
I understand the point you are attempting to make. In the real world not to many ops will run a "virgin" radio. It will be at least peaked an tweaked, something done for AM modulation, of course most like to see the meter swing. ( how many ops sit there and watch their output on the watt meter every time they key?).
By comparing them in "stock" configuration is really the unfair comparison. The Galaxy would not be on freq, the clarifier not opened to keep it on freq, and they both would put out the same amount of wattage as per FCC specs.
So without even having them on my bench or connected to any antenna or test equipment, I would say the Cobra would be the better of the "stock" comparisons due to freq stability and the fact that the factory techs pay more attention to detail when aligning the Cobra compared to the galaxy factory techs.
By comparing them "stock" really you are comparing the alignment of the radio by the factory, not comparing the operating characteristics of each radio.
The radio's need to be aligned for optimum performance on TX and RX then compared.
BTW the Honda accord already smokes the Ferrari in several categories stock from the factory.
Less expensive to purchase and maintain, better gas mileage, parts readily available and affordable. Honda now manufactures many of their vehicles here in the good old U.S.A. so it is probably made in America.(y)
A Galaxy 949 is not in the same League or even close to a side mic 148. The Cobra 148 is the industry standard for AM/SSB CB radios and the Galaxy 949 and 959s are just typical crap Made in China.
This is an unfair comparison. Compare BOTH radios out of the box.[/QUOTE]
Comparing 2 cb radios right out of the box is absurd because no one runs them that way. Kind of like comparing a FULL factory stock 1970 Hemi Cuda to a 2010 Chevy Camaro Z28. The Camaro would beat the Hemi because in 1970 radial tires weren't even invented and the Cudas came with bias ply 14" tires.....the camaro has wide radial tires and traction control.
Put drag radials on both cars, disable the traction control.....the Hemi would destroy the Camaro.
Reactions: Rebel Outlaw
What I'd like to see is a brand new Chinese 148GTL vs. a brand new Chinese DX-949, both with the basic alignment, tune and receive mods.
I'm looking at getting a new radio and I'm trying to choose between these two.
    May 15, 2024 @ 14:55 UTC
    Everything is El Dead-o. Joy!
