on a cobra 29. there is a red wire that is solder on board near R-46. where does the other end of wire go. its disconnected in this radio and i was wordering were to connect it.
thanks
Oh no! The disconnected end of that red wire was supposed to be connected to the smoke supply in the radio. Without it connected, the smoke all escaped! :shock:
don't worry i took care of the smoke problem. i see the cobra 29's cann't hold up getting run over by 18 wheeler at 79,560 lbs gross .metal cases just cann't take the pressure junk......
lmfao ,damm can you rebuild it. or see if it works now
i bet it won't smoke no more...if you do have it i will buy the parts off you..i sure any flat<lol rate box will work for cheap shipping..
