Cobra 4 pin to cpi 2000 4 pin ?
Crambone
I Support WorldwideDX.com!
Jan 22, 2019
563
175
53
58
Can anyone tell me what the adapter wiring would be? I have a cobra 4 pin mike and want to make an adapter to cpi 2000.
Thanks Andrew
From this thread: https://www.worldwidedx.com/threads/cpi-2000-mic-wiring.29842/
CPI 2000 mic wiring:
Pin 1 is Audio
Pin 2 is Ground
Pin 3 is TX PTT
Pin 4 is TX PTT return
Connect pins 3 and 4 through the PTT switch to make the radio transmit.
Which, I think, in D104 T-UG8 four wire mic wire colors would be:
Pin 1 Audio
Pin 2 Shield & Blue
Pin 3 Red
Pin 4 Black
Then set the D104 to relay keying (the E/R switch to R).
That's based on the diagrams from this site:
I've never actually tried this, so proceed at your own risk. Not responsible if your radio explodes or opens a portal to an alternate dimension, etc.
