Colt 357A PLL Problem C5121
SuperLid
Feb 6, 2020
1,551
1,595
173
NYC Metro
I have no experience with this PLL and there are no service docs that I can find, apart from a datasheet for the C5121. This leaves me with some questions, that hopefully someone with experience knows the answers to.
1: The channel selection is stuck on channel 9. No up or down changes.
2: The radio does receive signals and will change when the VCO tuning is changed.
3: What is the unlock pin voltage level supposed to be when unlocked?
4: What is the VCO voltage when tuned and from where is the test point?
5: This radio has never worked correctly. It was given to me a long time ago and I just found it. I figured I would try it.
Thanks,
SL
Sorry, I don't know the PLL.
Curious that it is stuck on channel 9, does it have a channel 9 switch?
The CB PLL databook has the following snippet about that particular PLL.
I would expect the VCO voltage to be around 2/5 of whatever the PLL supply voltage is (at ch20). 2/5 instead of 1/2 because varactors move more at lower voltage and moving it down gets it more into the linear-ish range where the pF's move more with voltage (centers the range of the varactor that way).
It is CMOS pll. Fragile to static etc...
If crystal is OK, then PLL is dead.
Mike
I already tested the crystal. It was 6 KHz off, so I replaced it, with a good one. Same problem. Would you know, if the radio gets stuck on CH 9 when unlocked?
I also grounded the U/D pin, no change. The chip is doing things, but I am suspecting it is a bad PLL.
From my expirience with C5121 there were two causes of stuck at channel 9. Bad chip or not working crystal resonator. (Check capacitors at the crystal)
VCO out of lock still allowed to change channels.
man this is a hard chassis to find info on!
I did run across this thread, and the radio in it might be like your colt.
I did find that thread as well. Unfortunately, they are quite different.
I tried canvassing what radios used this PLL in Franklin's PLL data book and it seems not one of them has info in SAMS or on CBTRICKS. So the only info I have on it is the little coverage in Franklin's book.
Wish I could help...
Thanks for trying. I think I m done with this one. It isn't anything special and I was just trying to beat the odds. I have better radios to fix and too many of them.
