CQ WW WPX Contest, SSB 2021
BJ radionut
6m addict
I Support WorldwideDX.com!
May 9, 2008
4,833
5,972
623
35 miles East of Indianapolis
0000Z, Mar 27 to 2359Z, Mar 28...FRIDAY 8:00 PM EDST thru SUNDAY 7:59 PM EDST
This is the "Work All Pre-Fix" Contest:rolleyes::LOL:
Worldwide
Mode: SSB
Bands: 160, 80, 40, 20, 15, 10m
http://www.cqwpx.com/rules.htm
OBJECTIVE:
For amateurs worldwide to contact as many amateurs and prefixes as possible during the contest period.
EXCHANGE:
RS(T) report plus a progressive contact serial number starting with 001 for the first contact.
Prefix Multipliers:
The prefix multiplier is the number of valid prefixes worked. Each PREFIX is counted only once regardless of the band or number of times the same prefix is worked.
A PREFIX is the letter/numeral combination which forms the first part of the amateur call.
Examples: N8, W8, WD8, HG1, HG19, KC2, OE2, OE25, LY1000, etc.
Any difference in the numbering, lettering, or order of same shall count as a separate prefix.
Fun Contest!!
I will be operating from W8PR this weekend.
We will be using "Special Pre-Fix"
WF8J.
I will be at the board from 10:00 PM EDST both Friday/into Saturday morning and again 10:00PM EDST Saturday/Sunday morning most Generally 40/80 meters.
I will "fill-in" at various other times "at the mic" or be working as a logger for other op's.
Daylight hours primary operation will most likely be 20/15 meters...maybe 10m late afternoon if conditions allow!:confused:
.Forecast...
Solar activity is expected to be very low, with a slight chance for a
C-class flare, on 26-28 Mar.:mad:
.Forecast...
Quiet to unsettled conditions are expected for the remainder of 26 Mar
becoming mostly quiet by 27 Mar. Late on 27 Mar to early on 28 Mar, a
CIR, in advance of another negative polarity CH HSS, is expected to
impact Earth. Conditions are expected to increase to unsettled to active
levels, with G1 (Minor) storm levels likely beginning on 28 Mar.:confused::oops:
solar101vhfpic.php
Have fun...Hope to put many "in the log" this weekend.
All the Best
Gary/W9FNB
So far with POOR band conditions.
500+ contacts...329 pre-fixes worked
close to 400K+ points.
go back to board around noon today...15 meters has some life but limited to mostly South America from Ohio.
May give 10m a try...but cluster looks pretty DEAD
All the Best
Gary
Operating de WF8J
20/40 meters been the biggest providers
Reactions: binrat
Sunday Am UPDATE:
TEAM status Contacts...1070
Pre-fixes worked...520
Score: 1,261,520 points...Certainly not the best score stateside, but I think respectable for us with still 12 hours left in contest!(y):D
Running only 1 transmitter w/ multiple op's
All the Best
Gary
Reactions: binrat
