CRT Hercule Turbo no Modulation
Wenefe
New Member
Jan 11, 2026
5
Hello
I have a CRT Hercule Turbo
Unfortunately, it has no modulation in any operating mode
I would appreciate your help
Best regards from Austria
Hello
And that's a reason to post in old threads?
We unite in pain.
What measurements and tests you done so far?
Mike
Thanks for the quick reply. The device was already with a technician, but unfortunately he gave up. Now I want to try it myself. I have measuring devices, soldering stations, etc. I just need a nudge in the right direction.
Apply audio from signal generator on microphone socket, put it on TX and check if on pin1 marked blue you have a signal from generator. If not, follow red line back to mic socket to find where it disappear.
Mike
Reactions: 19wrc333
Thanks for your help.
I disassembled the device today.
I'll get a signal generator tomorrow.
Can someone show me where the IC is? I can't find IC 16 on the mainboard.
Best regards, Werner
IC16 is an 8-pin DIP, 458.458 dual op-amp. It is used for amplifying the mic audio, and for handling transmit/receive switching. I've circled its location in yellow in the uploaded image.
Incidentally, this is the same chassis as the original RCI 2950/2970 radios and their base-station derivatives.
here is a tip on troubleshooting modulation problems
in these radios.
there is a built-in audio generator.
the "roger beep"
strong roger beep audio is fed in before that
mentioned double op-amp.
usually on these radios, the AMC and ALC is turned off,
and/or the components cut out. You hear it all the time,
the roger beep over modulates the signal. maybe causing
other problems, that I have seen.
Turn on the roger-beep. test that, for a over modulated
AM signal. if so, then the problem is up around the
MIC input circuit. you can check FM and SSB also.
A good fast test to get in the right direction of
low modulation problems.
I had a few of these RCI/Galaxy radio with weak AM TX.
Normal carrier power, low amplitude modulation.
the roger beep signal was piss-weak also.
The problem was that big electrolytic capacitor
in the modulator section C190, in series with the 15 ohm resistor.
I had another guys added external amp acting up.
told him to turn the roger-beep off. then all OK.
that is my $.05 worth (a nickel's worth) (inflation, and no more penny's)
