davemade transistor conversion
coyotekid28
Jun 17, 2013
22
4
13
Purchased a davemade m200 which is supposed to be 1 2sc2290 driving 2 2sc2879's and it has a different set up . It is set up 1 Motorola 3800 9126 driving 2 2sc2879's any ideas on that Motorola transistor just curious amp does what the specs state it should . thanks
I realize you are a newcomer here but expecting an answer in less than a hour and a half after asking is expecting a little much. Sometimes you hit it right and get an answer in minutes if the right person is online and other times it may take a day or more.
Yep and that's my bad I told a few others I was sorry and was actually using my phone and didn't realize it had posted I got it figured out my apologies cheers
If the amp is swinging 400 watts peak, don't worry about it. As readily available as 2290s are, it's puzzling why someone would put a different driver pill in there.
  • @ heartbreaker3473:
