I agree with previous posters in that you need to identify the type of noise. Is it just general static or is there some sort of "note" to it, as in a discernible tone under neath it? If it sounds a bit like a 50/60 or 100/120 cycle hum in the static, then some of your issue is likely from the house wiring and no related to the antenna, possibly a ground loop somewhere. An earlier posted suggested flipping off the main breaker and run the radio on a battery for a bit to see how much noise is still there. I would agree with that as a tool to help eliminate sources. Major suspects are any electronics or appliances that use switching power supply regulators. If the breaker trick DOES reveal its something in the house, then what an earlier poster suggested is correct - unplug things one at a time to isolate the noise source. Don't just turn it off as many items will still be using power even in an off state. Hopefully with a little time and effort you can determine the noise source and post your findings to this thread for more specific advice.
