Dropping volts
If it is dropping that bad under load its almost guaranteed the alternator or voltage regulator ( if external) that has died
Just had to complete download on charging system all perfect . Starting to think something in my amp is causing it but what part or component .
OK so you had TWO issues with the negative lead? One at the [post and another at a splice? At least you found it. Most people fail to think about the negative lead which is at least as important as the positive.
Reactions: mrgumby
Yes all good . However I re ran new lines and Anderson clips. I ran ground from amp to seat bolt , at first I was squealing bad removed seat bolt scraped all the paint away and was perfect . Not sure why the paint at seat bolt caused me to squeal?
It was not making as good a ground connection as you may think it was. Poor ground connections can cause all kinds of RF problems with amps and cause them to squeal.
Reactions: BJ radionut
Yes sir. All that time running around losing all those volts I wonder how much I was actually putting out of my amp? I’m thinking no were near 100 percent .
Pretty common issue, often people don’t run large enough wire or fail to get a good ground. As Captain said it can create some weird issues.
Reactions: Ziploc
