Dropping volts
Ziploc
Mar 19, 2016
299
135
53
52
Need help guys, I’ve been running a 2 pill 1446 in my truck forever. Here recently when I key up and modulate my needle drops on battery gauge on truck and almost shuts it down at times. Never ever a issue . What’s going on ? Thanks also battery is brand new .
Unfortunately it’s doing it again. At my wits end. Was thinking is there a component in the amp that could be causing this
If it is dropping that bad under load its almost guaranteed the alternator or voltage regulator ( if external) that has died
Reactions: NZ8N
