Eimac 4CX
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
Are These accurate specs:
Plate Dissipation (Max.) 25,000 Watts
Screen Dissipation (Max.) 300 Watts
Grid Dissipation (Max.) 180 Watts
Frequency for Max. rating (CW) 230 MHz
That's 25 thousand Watts output right? and it's a 25LB tube:blink:
A 4cx ?????
there are many in the 4CX series of tubes..
Data sheets on RF power Tetrodes
Are you looking for BIG tubes?
Air Cooled?
Water Cooled?
Vapor cooling?
One with a Pond out front ?
Look at the 4CN300,000 Tube.
http://www.g8wrb.org/data/Eimac/4CM300000GA.pdf
All you need is a Hydro-electric power plant to run it.....
Below is a Smaller version.
Actually Jeff that is a test set up for Eimacs two million watt transmitter tube.
Triode Electronics-Mega Ongaku!
That's 25 KW worth of dissipation, not output. Unless the amplifier is only working at 50% efficiency you should be able to achieve over 25 KW output in AB1 service. Those are just guidelines for continuous duty service, not intermittent communications service where it could safely do far more with ample cooling. "Homebrew" projects utilizing tubes like these are often more limited by the design of the power supplies and RF deck rather then the tubes capabilities.
Kind of like using a pair of 4CP250B's to make 10Kw in radar service. I dare say that most people are concerned with what a tube will do in voice service and some even care about what they will do in clean AB voice service. A few care about class C voice service (yuck) and almost nobody cares about pulsed service. :D
Given enough mic gain and accompanying RF cutoff, I do believe some people have figured out an alternate voice mode utilizing pulse. May require a little tweaking to get a desired duty cycle though.
  • @ Wildcat27:
    63Sprint has left the room.
