The Yaesu Ft 101 B with the 11 slot is a legal radio, however it is not legal to use it on The CB frequencys.
It is not "Type Accepted" for CB. A Long time ago, 11 meters was a Ham band, then FCC changed the rules, and made it class d cb radio service.
So in a nut shell, you can have the radio, but you cant use it to transmit with. You can use it to listen.
The best thing to do, is study for your Tech Lic, it is not hard to pass the test, and then you can run that radio on Ten Meters.
Ten Meters works just like 11 meters when the band is open, is a lot cleaner, and you don`t have to worry about it. Heck if you study just a little more, and do the general, you can run Legal Limit, 1500 watts and be legal as Ice cream
Funny thing is, you hardly ever need to, 150/200 watts on SSB on ten meters, and you really can work the world when the Cycle is up and the band is open.
