so my cobra 2000 gtl on the internal power supply shows 14.20 volts when the radio is keyed it only drops to 14.12
then when i switch to the external power supply set at 14.30 when the radio is keyed it drops to 13.52 volts but the volt on the power supply at the terminal doesn't drop they only drop inside the radio only drawing 2.3 amps so my question is why the 1-volt drop tr-41 was upgrade thinking the 3756 regulator
